Squeaking sound after change shock asorber. Need advice
Hi Everyone,
Wonder if anyone of u encounter squeaking sound after shock asorber change..recently juz changed asorber and use it for around 2500km and the squeaking sound start to surface. The sound occur everytime i go over hump ,during the acceleration from complete stop and also during left turn..
had brought it back to the workshop to diagnose but they cant find where the sound came from..
hope any experince bro or sister can give some advice..
- MCDS
- Civic ES/EU/EP Moderator
your insulators are gone. replace them. around SGD$20 a piece. but labour is extra as got to tia the suspension from your body to install.
try OSK at AMK Autopoint2 off AMK ave 5. opposite Kenny's Alignment... level 4.
The done mine before. quite good.
Sound
Mcds bro, I had this sound too ..but my is bc Coil over.. After slow down go thru humps an hear squeaking sound but I'd drive fast fast no sound
- MCDS
Re: Sound
guniang6618 wrote:Mcds bro, I had this sound too ..but my is bc Coil over.. After slow down go thru humps an hear squeaking sound but I'd drive fast fast no sound
That's WHY la... must drive FAST... hahaha...
same thing la... the leather or whatever material sound insulation washer is worn out... it is where the spring or suspension contact the car body... so when you drive slow and go over things or slope like mscp, it will move a bit... because it's metal to metal now on account of the worn out bushing(s) you will hear the squeaking sound as the suspensions move as your car negotiates slow torsion turns or humps.
drive fast? actually still making noise la... except your engine and exhaust noise is louder than the squeaks...
- MCDS
ok. keep going back to them to see if they can help idenify and eliminate the noise problem.
this is not a unque case, many cases, in fact most cases, the squeeks will take a while to identify and rectify. it takes time and patience. sometimes money ... mostly just tighten or loosen ...
its the zeroing in on the source that is the headache...
have fun hunting ...
- MCDS
haha... my Turtle...
squeaks, rattles, shakes, vibrates, when rain, sounds like a jack hammer is going on in the cabin... step brakes squeaks like hell, driving with windows down can hear more metalic noises ...
but I love the sounds... all of it... tells me that Turtle's ALIVE.....
