GB for CL7 R/A front n rear wheel hub bearing
- viper76
Hi guys a few bros front n rear wheel hub bearing wear off Liao n need replacement. Therefore have liase with thian seng will do a gb for front n back. Front bearing cost $40 per side (brand : ntn oem brand) n rear wheel hub bearing cost $120 per side (brand: ntn oem brand) . Anyone interested pls list down ur order n pm me ur contact no , name , require u to tx me the Amt to order. If cheaper will refund the difference. I let tis list run till Friday 15th July. Then I go place order Liao.
LAtest update on price n firm liao...brand also firm...
1) viper76 ( 1 pair front bearing ) mat : $90
2)
3)
4)
5)
6)
7)
8 )
9)
10 )
2)
3)
4)
5)
6)
7)
8 )
9)
10 )
- MrMurderman
- 10 000rpm Over Rev
Re: GB for CL7 R/A front n rear wheel hub bearing
viper76 wrote:Hi guys a few bros front n rear wheel hub bearing wear off Liao n need replacement. Therefore have liase with thian seng will do a gb for front n back. Front bearing cost $45 per side (brand : ntn oem brand) n rear wheel hub bearing cost $155 per side (brand Honda oem) TS say if more order more cheaper. Anyone interested pls list down ur order n pm me ur contact no , name , require u to tx me the Amt to order. If cheaper will refund the difference. I let tis list run till Friday 15th July. Then I go place order Liao.
2) MM ( 1 pair front bearing ) :$90
3)
4)
5)
6)
7)
8 )
9)
10 )
殺很大!ï¼
3) Speed-R (front n back bearing) :$90 + $155
4)
5)
6)
7)
8 )
9)
10 )
4)
5)
6)
7)
8 )
9)
10 )
-Nissan Sunny 1.5
-Mitsubishi Lancer GLX 1.6
-JDM Euro-R 2L
-Honda Odyssey Absolute 2.4L
-JDM Euro-R 2L
Speed-R wrote:Hi guys a few bros front n rear wheel hub bearing wear off Liao n need replacement. Therefore have liase with thian seng will do a gb for front n back. Front bearing cost $45 per side (brand : ntn oem brand) n rear wheel hub bearing cost $155 per side (brand Honda oem) TS say if more order more cheaper. Anyone interested pls list down ur order n pm me ur contact no , name , require u to tx me the Amt to order. If cheaper will refund the difference. I let tis list run till Friday 15th July. Then I go place order Liao.
4) lokey (front n back bearing) :$90 + $155
5)
6)
7)
8 )
9)
10 )
lokey wrote:Speed-R wrote:Hi guys a few bros front n rear wheel hub bearing wear off Liao n need replacement. Therefore have liase with thian seng will do a gb for front n back. Front bearing cost $45 per side (brand : ntn oem brand) n rear wheel hub bearing cost $155 per side (brand Honda oem) TS say if more order more cheaper. Anyone interested pls list down ur order n pm me ur contact no , name , require u to tx me the Amt to order. If cheaper will refund the difference. I let tis list run till Friday 15th July. Then I go place order Liao.
5) tleslie (1 pair front + 1 pair rear) : $400
6)
7)
8 )
9)
10 )
- viper76
tleslie wrote:lokey wrote:Speed-R wrote:Hi guys a few bros front n rear wheel hub bearing wear off Liao n need replacement. Therefore have liase with thian seng will do a gb for front n back. Front bearing cost $45 per side (brand : ntn oem brand) n rear wheel hub bearing cost $155 per side (brand Honda oem) TS say if more order more cheaper. Anyone interested pls list down ur order n pm me ur contact no , name , require u to tx me the Amt to order. If cheaper will refund the difference. I let tis list run till Friday 15th July. Then I go place order Liao.
3) Speed-R (front n back bearing) :$90 + $155 ---> bros figure wrong
4) lokey (front n back bearing) :$90 + $155 ----> bros figure wrong ar..
6)
7)
8 )
9)
10 )
- viper76
bro u want ur back 1 side or 2 side??? 2 side = $310lokey wrote:Speed-R wrote:Hi guys a few bros front n rear wheel hub bearing wear off Liao n need replacement. Therefore have liase with thian seng will do a gb for front n back. Front bearing cost $45 per side (brand : ntn oem brand) n rear wheel hub bearing cost $155 per side (brand Honda oem) TS say if more order more cheaper. Anyone interested pls list down ur order n pm me ur contact no , name , require u to tx me the Amt to order. If cheaper will refund the difference. I let tis list run till Friday 15th July. Then I go place order Liao.
5)
6)
7)
8 )
9)
10 )
- viper76
bro u want ur back 1 side or 2 side??? 2 side = $310Speed-R wrote:Hi guys a few bros front n rear wheel hub bearing wear off Liao n need replacement. Therefore have liase with thian seng will do a gb for front n back. Front bearing cost $45 per side (brand : ntn oem brand) n rear wheel hub bearing cost $155 per side (brand Honda oem) TS say if more order more cheaper. Anyone interested pls list down ur order n pm me ur contact no , name , require u to tx me the Amt to order. If cheaper will refund the difference. I let tis list run till Friday 15th July. Then I go place order Liao.
4)
5)
6)
7)
8 )
9)
10 )
6) murdererman ( 1 pair front : $90 )
7) quickrazo ((1 pair front + 1 pair rear) : $400
8 )
9)
10 )
8 )
9)
10 )
- viper76
Quickrazo wrote:Hi guys a few bros front n rear wheel hub bearing wear off Liao n need replacement. Therefore have liase with thian seng will do a gb for front n back. Front bearing cost $45 per side (brand : ntn oem brand) n rear wheel hub bearing cost $155 per side (brand Honda oem) TS say if more order more cheaper. Anyone interested pls list down ur order n pm me ur contact no , name , require u to tx me the Amt to order. If cheaper will refund the difference. I let tis list run till Friday 15th July. Then I go place order Liao.
6) quickrazo ((1 pair front + 1 pair rear) : $400
7)
8 )
9)
10 )
