Servicing Hybrid Cars.
Honda's Hybrid technology, including the Civic Hybrid (FD3) and the Insight (ZE2)
nunogomes
Post by nunogomes » Thu May 05, 2011 2:16 pm
Is there any difference in servicing being done on a hybrid car?
If yes, any reputable dealers out there?
Thank you guys!
nikeian
Servicing
Post by nikeian » Mon May 09, 2011 2:17 pm
Insight can be serviced as a normal car. Unless you have a problem with your IMA battery, then its best to check with your sales.
rule of the thumb, do not let them touch the battery for no whatever reasons (which is at the bottom of passenger back seats.) they can check the battery at the front, but not the IMA battery.
Mine usu. change engine oil and oil filter. Occasionally checks on the brakes and for your personal checks : tyre pressure (every fortnight)
They should also change or clean your air filter. If yours is K&N filter - that is to be serviced every 10,000 or 50,000km. (Whichever pleases you)
Those Insights passed 20,000km should be checking their brake fluids and coolant.
Hope this helps.
Jason8052
Re: Servicing Hybrid Cars.
Post by Jason8052 » Thu May 19, 2011 9:06 pm
nunogomes wrote:Is there any difference in servicing being done on a hybrid car?
Thank you guys!
No difference...
Service as normal car
The Feeling Never End
xiaolong
Post by xiaolong » Thu Dec 20, 2012 11:35 am
Do u guys service outside of kah motor? Understand tat the battery cost a bomb if out of warranty.
hyridcar
Post by hyridcar » Sun Sep 29, 2013 10:07 pm
Thank you guys!
try read http://www.sgcarmart.com/directory/merc ... ?MID=14375
electric machine
jonathanzy
Post by jonathanzy » Thu Jan 28, 2016 5:22 pm
Thank you guys!
No difference...
No difference? the car inside different using high voltage components and electrical motor how can be serviced the same way as normal car?
Hybrid cars use special electric transmission and they do not have conventional starter motors unlike petrol cars. They also have a hybrid car battery that is temperature sensitive and requires regular maintenance to ensure optimal performance of the hybrid car
