suspension ek/eg
Civic model year 1980 - 2000
angmohbeng
Post by angmohbeng » Mon Jun 27, 2011 9:19 pm
grandpa-VTEC wrote:
Will_SG wrote:
vtec5045 wrote:Wa very chim leh brother. Like that if deal with someone, I must arrange to meet at workshop so that no hassle later.
I was quite confused earlier and found there are 3 varieties when I change my LCA and Coil-over fork.
Ball joint - DC & some EG
Fork wide - some EG (For BC coil-overs the difference between the EG and EK is just the width of the fork)
Fork narrow - EK
ball joint is also for EF9 but for other non SiR EFs suspension is same as EG ;)
I checked my ED9 CRX, it's also ball joint. @grandpa vtec I guess "other non SiR EFs" refers strictly to EFs, not covering ED/EE as well?
Civic ES5 2006-2009 "Pearline"
Civic EG9/DB8 Front 2011 "Kitty"
CRX ED9 2011 "Crystal"
Integra GS-R DC2 2013-2016 "Anakin"
Acura TL Type-S UA7 2016- "Sylvie"
Prelude BB6 2017- "Project Prelute"
YEN96
Post by YEN96 » Mon Jun 27, 2011 10:51 pm
anyone have info on BC coilovers ? there are 2 models rite , BC V1 and BC BR ...which is higher grade and wat the difference, how much cost for both ?? FK quote $1250 is for which one ah ???
fredphua
Post by fredphua » Sun Jul 03, 2011 1:21 am
YEN96 wrote:anyone have info on BC coilovers ? there are 2 models rite , BC V1 and BC BR ...which is higher grade and wat the difference, how much cost for both ?? FK quote $1250 is for which one ah ???
Hi, I've asked for quotes before as well. It's for v1 but please confirm with the seller again before committing. Cheers!
grandpa-VTEC
Post by grandpa-VTEC » Mon Jul 04, 2011 10:54 am
angmohbeng wrote:
grandpa-VTEC wrote:
Will_SG wrote: I was quite confused earlier and found there are 3 varieties when I change my LCA and Coil-over fork.
Fork narrow - EK
most prob yours has been converted to the SiR's suspension. Ive checked around already. Even JC's suspension is using the fork type which allows him to use aftermarket rear control arms. something which mine cant.
Speeding has never Killed anyone....suddenly becoming stationary is what Kills you ---- jeremy Clarkson
fromkunming
Re:
Post by fromkunming » Fri Feb 09, 2018 10:55 am
Skie wrote:Hi bros,
I would be scrapping my EH9 sometime this month n have a pair of D2 LCA.
Its for the EG fork type. Used about a year, bought brand new.
Do PM me if interested.
Available?
