Sharing of Vehicle Inspectionï¼
- shadow dancer
Hi bros,
Care to Share...
My car is deal for inspection next month and because this is my first inspection, I'm wondering anyone can provide some valuable information of the things to take note off.
The prefer inspection centre?
Thanks...
Care to Share...
Thanks...
Ice Melt and Friendship Form
- shadow dancer
Inspection
Thanks for your information. Does body kit and Rim spacer affect the inspection?
Re: Inspection
No, as long as you dont do anything illegal in your car should be ok. Inspection only take less than 10-15min or shorter if everything okshadow dancer wrote:Thanks for your information. Does body kit and Rim spacer affect the inspection?
- shadow dancer
Thanks bros, been hearing alot of failing incident. Guess is only my headlight is going to fail me.. Is it preferable to let the workshop drive my car there?
- fivelement
- shadow dancer
Re: Thanks
Workshop drive may not make much difference. As long as your car meets the requirements and have no illegal mods, should be fine. I remember they had to test and re-test my tinting cos the window was too dirty.. hahahashadow dancer wrote:Thanks bros, been hearing alot of failing incident. Guess is only my headlight is going to fail me.. Is it preferable to let the workshop drive my car there?
- shadow dancer
Inspection
Thank you bros for all your valuable advices, I'm sure that it will act as reference for our bro out there.
