Dent Removal
Automobile related topics
guoming``
10 000rpm Over Rev
10 000rpm Over Rev
Dent Removal
Post by guoming`` » Wed Dec 29, 2010 8:54 am
anyone got contact for dent removal? has been trying to find but unable to find it. Please advise. thanks. :wink:
Expect for the unexpected.
wpyeo
SHC Die Hard!!!
SHC Die Hard!!!
Post by wpyeo » Wed Dec 29, 2010 10:24 am
guoming``
10 000rpm Over Rev
10 000rpm Over Rev
Post by guoming`` » Wed Dec 29, 2010 11:07 am
thanks uncle yeo... long time no see!!
guoming``
10 000rpm Over Rev
10 000rpm Over Rev
Post by guoming`` » Wed Dec 29, 2010 11:10 am
zzzz... i want the contact... not inside the clips.. :cry:
Alvinyzw
10 000rpm Over Rev
10 000rpm Over Rev
Post by Alvinyzw » Wed Dec 29, 2010 7:13 pm
If your dent not deep can use touch up pen to cover it. :wink:
YEN96
Post by YEN96 » Wed Dec 29, 2010 7:48 pm
May i know wat is the difference between EF civic GL and concerto ????????
Alvinyzw
10 000rpm Over Rev
10 000rpm Over Rev
Post by Alvinyzw » Thu Dec 30, 2010 6:32 pm
YEN96 wrote:May i know wat is the difference between EF civic GL and concerto ????????
Honda Civic GL, a.k.a 4th Gen Civic:
Produced in 1988, the Honda Civic was significantly redesigned. The suspension had a radical re-configuration with what Honda called "double-wishbone suspension" on all four corners, wheelbase was increased to 98.4 inches (250 cm), and the body was redesigned with a lower hood line and more glass, giving less drag. Rear suspension however is more accurately described as multi-link trailing arm suspension since the upper control arm only has a single anchor and there is toe control used on the main trailing arm.
The base model of the 4th generation Civic had a 1.2 L SOHC, this single carbureted engine was not available for the European and American market. (23L and 23U for the Japanese market) 1.3 L SOHC single carbureted engine.
The 1.5 L SOHC engine came in a wide variety of models, dual-point injection, single carbureted and dual carbureted. Those engines were available in the Japanese-market 25X and 25XT,
Top model of the hatchback was the Japanese SiR EF9 with the 160 hp (120 kW) (B16A DOHC VTEC 1.6L 160 hp 7600rpm) The Japanese version of the Si featured a (ZC) D16a8/9 1.6 L 16V DOHC engine.
Honda Concerto:
The Honda Concerto was an automobile produced by the British division of the Japanese manufacturer, from 1988 to 1994. The Concerto was sold in both liftback and sedan form. In most European countries, and Australia, it was sold as the 5-door liftback version only, as a replacement for the discontinued Honda Integra 5-door liftback. The saloon version lasted until 1993 for most nations.
In Japan and other Asian/Australasian countries, the Concerto was also available with an SOHC 1.6L dual carb engine. 4WD was also an option in Japan. Interestingly the Concerto range featured a 1.6 16v SOHC engine, quite an unusual design to have sixteen valves on a single cam.
The Concerto was sold internationally on a platform which was larger than the popular Civic. Just like the 5-door Integra it replaced, it offered more features than the Civic and was more prestige market.
Source: Wiki
8) 8) 8)
SpeedMaster1979
Re: Dent Removal
Post by SpeedMaster1979 » Fri Dec 31, 2010 11:48 am
guoming`` wrote:anyone got contact for dent removal? has been trying to find but unable to find it. Please advise. thanks. :wink:
Lye Design- 97235915(Ah Lye),he is the best man for the job!
Speed is nothing without control
guoming``
10 000rpm Over Rev
10 000rpm Over Rev
Re: Dent Removal
Post by guoming`` » Thu Jan 06, 2011 9:07 am
thanks bro.. located at?
wpyeo
SHC Die Hard!!!
SHC Die Hard!!!
Re: Dent Removal
Post by wpyeo » Thu Jan 06, 2011 9:10 am
Ang Mo Kio Industrial Park 2A #04-04
