Wideband O2 Sensor Readings
Posted: Sun Aug 22, 2010 11:26 pm
by Viper
Hi all tech gurus...
Got a wideband sensor cum meter installed lately (using Bosch LSU 4.9 sensor) and realised a weird behaviour thus seeking some clarifications.
I observed that under certain load conditions eg. when I am cruising at say 80km/h, and releases my throttle fully, the reading will swing to say 20.00 (max reading on left end) which is lean for a few seconds before it swings back into the more normal ranges eg. 13.1 - 14.8 range.
Is this normal?
Re: Wideband O2 Sensor Readings
Posted: Mon Aug 23, 2010 7:56 am
by UltraBear
Viper wrote:Hi all tech gurus...
Is this normal?
==> yes... should only happen when you let go of your throttle... usually happens when you're doing part or full throttle... should not happen during gentle driving....
Wideband O2 Sensor
Posted: Mon Aug 23, 2010 9:23 am
by Viper
Hi bro,
Thanks for the info.. Phew... Was worrying something was wrong.
Yup, it only happen when I abruptly let go off the throttle (example when reached a certain speed and a let go of the throttle and roll) and it will drop for a few seconds before it swing back to usual range.. Normal driving won't happen...
Cheers.
Posted: Mon Aug 23, 2010 11:53 am
by UltraBear
Viper wrote:Hi bro,
Cheers.
==> :-) ... which brand of the WB are you using on your car?
Wideband O2 Sensor
Posted: Mon Aug 23, 2010 4:33 pm
by Viper
Mine is GlowShift which is black with blue LED digital display.
It comes with a controller box and optional data logging module. Calibration also done via this box.
