need help coz car wont start
Posted: Sun Jul 18, 2010 10:19 pm
by mugen_yaz
im having this problem on my esi dat is truly bugging me... normally when i turn the ignition key, i will wait for the checklight to die off then i can crank the engine but now it seems that the check light wont die off n my engine won't start. especially after it rains or its a cold night..keep cranking but engine wont start at all.. my mechanic change the fuel pump relay because previously it also has this problem, but after changing its worse...it takes a longer time to start n now it wont start at all. if any of u guys might know what the symptoms might be do help me..thanx for taking the time to read my post.
Re: need help coz car wont start
Posted: Wed Jul 21, 2010 1:29 am
by UltraBear
mugen_yaz wrote:im having this problem on my esi dat is truly bugging me... normally when i turn the ignition key, i will wait for the checklight to die off then i can crank the engine but now it seems that the check light wont die off n my engine won't start. especially after it rains or its a cold night..keep cranking but engine wont start at all.. my mechanic change the fuel pump relay because previously it also has this problem, but after changing its worse...it takes a longer time to start n now it wont start at all. if any of u guys might know what the symptoms might be do help me..thanx for taking the time to read my post.
==> where do u stay? If you're around seng kang, i can drop by check for you... I used to own a EH9 and "played" with it before..
Posted: Wed Jul 21, 2010 4:27 am
by bugis_kid
ecu
Posted: Wed Jul 21, 2010 4:29 am
by bugis_kid
batt terminal check.
wiring check via ecu error check code
Posted: Wed Jul 21, 2010 8:50 am
by mugen_yaz
thanx ultrabear....but i stay in bukit panjang...anyways i called a tow truck to tow my car to my workshop to do a proper check n repair.. what to do when its reaching 20yrs old there are bound to be problems i guess...
Posted: Wed Jul 21, 2010 8:52 am
by mugen_yaz
bugis_kid wrote:batt terminal check.
thanx bugis kid, i will have my mechanic do that when the car reaches his workshop later today.. thanx for the help..appreciate it so much.
Posted: Wed Jul 21, 2010 4:19 pm
by mugen_yaz
bugis_kid wrote:ecu
ur ans was precise bugis kid....my ecu bakar liao...sianz...
Posted: Wed Jul 21, 2010 5:52 pm
by Gresini
Hmm... I also stay there... nvr seen such beautiful eg front b4 leh...
Posted: Wed Jul 21, 2010 5:59 pm
by mugen_yaz
Gresini wrote:Hmm... I also stay there... nvr seen such beautiful eg front b4 leh...
now not using angel eye anymore bro...... now on stock headlight n change to eg6 bumper plus mugen lip......last time was ori front bumper with angel eyes headlight...btw where u stay n wats ur ride? i live in bangkit rd.
