Idle problem
Posted: Fri Feb 12, 2010 2:50 pm
by MR Spyder
Guys, I'm facing a prob with my car's idling. It'd fluctuate between 600-900rpm all of a sudden, and at times, the car "shivers" like it's on e verge of stalling.
Issit due to a dirty throttle body?
Any idea what's wrong? :(
Posted: Fri Feb 12, 2010 8:01 pm
by jellyfish
have you done any mods recently?, try reset your ecu by removing your battery terminal for few mins then reattatch it, drive ard let the ecu relearn, should be ok, or else it might be due to idle valve or dirty tb due to lousy filtration :wink:
Idle prob
Posted: Sun Feb 14, 2010 1:24 am
by daboy14
Clean first ur iacv then im..
If all else fails reset ur ecu by removing
the ecu fuse loc at the fuse bix for at least
15.. This wud rebootvthe system and let the
ecu "idle leaen" again
Idle
Posted: Sun Feb 14, 2010 1:31 am
by daboy14
"idle learn"
