chances of my fuse blown?
Posted: Mon Feb 01, 2010 11:27 pm
by xiaopiggy
driving a eg5..
my high beam got light, low beam no lights.
tried swapping bulbs, doesnt help.
so wondering if its the fuse, or could it be the wiring in the bulbs that is spoilt?
fuse
Posted: Tue Feb 02, 2010 11:40 am
by 18luohan
Posted: Tue Feb 02, 2010 2:05 pm
by -echo-
ya, check ur fuse, try use the spare 10A fuse, if dun have, u can pluck out ur high beam fuse to try.(must use the same 10A) if it's working, den just buy a new fuse. if it's not working, den should be wiring le.. but most probably is fuse.
headlight
Posted: Tue Feb 02, 2010 3:43 pm
by 18luohan
Also, like to suggest use new set of Bulb or identical type ; not left side brand A and right side brand B which may cause uneven voltage.
Take care , this is a 18 years old lao chai!!!
Posted: Sun Apr 04, 2010 11:32 pm
by Matashi
i have the same problem. driving a jazz '04.
changed fuse, bulbs still same. stamford say wiring problem.
any other workshop to recommend? cos stamford say might take one whole day or two to rectify problem
