K&N Filter
Ah feng
K&N Filter
Postby Ah feng » Thu Jan 28, 2010 9:01 pm
Anyone know where to get K&N drop in filter?
Thanks.
saint jo
Postby saint jo » Fri Jan 29, 2010 8:45 pm
speedworks
67437288
$95
Turbo...
sTocK iS beST....
[size=59]世界上ä¸
Ah feng
Postby Ah feng » Tue Feb 02, 2010 3:14 am
Thanks EK4_JO
saint jo
Postby saint jo » Wed Feb 03, 2010 5:38 pm
no problems... :wink:
Turbo...
sTocK iS beST....
[size=59]世界上ä¸
Ah feng
Postby Ah feng » Thu Feb 04, 2010 3:15 am
EK4_JO wrote:no problems... :wink:
Bro, for drop in filter. Which brand would you recommend? :shock:
saint jo
Postby saint jo » Tue Feb 09, 2010 4:03 pm
KNN is good enough... if not biltz or mugen.. (both are more ex then KNN)
Turbo...
sTocK iS beST....
[size=59]世界上ä¸
Ah feng
Postby Ah feng » Fri Feb 12, 2010 1:49 am
I have friend who recommend open pod with custom made box up. So i am thinking whether to go for original drop in or open pod with customised box. Which are you using now?
saint jo
Postby saint jo » Fri Feb 12, 2010 8:48 am
i'm on stock airbox :lol: depends on wat's ur budget...go for choon custom fat tummy la..not bad...
Turbo...
sTocK iS beST....
[size=59]世界上ä¸
neonleon
Postby neonleon » Tue Aug 19, 2014 1:58 pm
Do not use knn filter.
My car R18 engine just died after using a drop in for one month.
It was not the oil used by knn as proven by knn.
The actual cause was due to the small particles that knn filter allows through that clogged up the MAF sensor..
Unable to start the engine after the car just died.
Cranking is good so battery n starter are ok. Fuel pressure is there too.
As the filter was the new thing used, So opened up the filterbox n found the upper box has a layer of fine dust inside. Did a quick blow on the MAF n reinstall. Was able to get the engine to run for a second or 2.
Next changed out the knn filter to my old airfilter, cleaned the inside of upper box and did a thorough blow clean of the MAF sensor with my mouth. Reinstall back.
And i was able to start the engine again.
So beware.
Return to “Integra”
