Rims
Posted: Thu Jan 28, 2010 8:29 pm
by garbage888
Hi
Any bros here know that if i want to swop my current CL7a 17" rims to the stock CU2 rims - which i believe is also 17" and still fit the CU2 stock tyres, can it be done.
I believe that the CU2 tyres are 225/50/17 and my current Cl7a is 215/45/17.
Cheers :D
Posted: Sat Jan 30, 2010 4:20 pm
by weaver87
H 888,
If 215/45/R17 is yr stock rims/tyres, then using 225/50/R17 will end up w a bigger OD on yr ride. Not very advisable but if u accept it, then it's yr choice.
The other issue is r both rides having same type of PCD n offset? If PCD same, then no problem. Offset can be corrected.
Bro James or bro lingamair may be able to help to confirm....
cheers!
