ody RB1 shift shock
ody RB1 shift shock
my ody has clocked close to 120k and is now experiencing jerk when the gear down shift. Chged mounting which was broke but shift shock still there. Mechanics pointed out is the torque converter problem. any bros got tis problem
Re: ody RB1 shift shock
Bro hv you been replacing the ATF regularly? it could be due to aging ATF. my milages is 210k and still going strong.......
previa333 wrote:my ody has clocked close to 120k and is now experiencing jerk when the gear down shift. Chged mounting which was broke but shift shock still there. Mechanics pointed out is the torque converter problem. any bros got tis problem
got leh.....i chge them every 25k. Anyway, will do a total flush n c how. Frankly, saw bro cleanwipe wack his autotrans like nobody business, also machiam like no problem. ..rb1 autotrans cant b tat lousy leh imorjj wrote:Bro hv you been replacing the ATF regularly? it could be due to aging ATF. my milages is 210k and still going strong.......
Bro u are the lucky few to witness White knight in action lei. Btw, u own the ody brand new? If bought used maybe the first owner had already injured the gear box Liow.
Try go for a full flush then see if problem still there boh loh... Honda gear box generally are one of the best be it auto or manual and engine too:)
previa333 wrote:got leh.....i chge them every 25k. Anyway, will do a total flush n c how. Frankly, saw bro cleanwipe wack his autotrans like nobody business, also machiam like no problem. ..rb1 autotrans cant b tat lousy leh imorjj wrote:Bro hv you been replacing the ATF regularly? it could be due to aging ATF. my milages is 210k and still going strong.......
Cos you do flushing mah....anyway even if you are changing ur gear box you might as well change the filtertoo. hope u get a gd one:)
previa333 wrote:bro, mi really sceptical abt chgeing filter will help. if spent another few hundreds n still don work, money down e drain again. Might as well do it once n for all at 1.2k sing dollar over at JB.
btw, was charged 200 bucks for atf chge which i felt was
Finally, got mi ody back.
When everything was assemble back by e workshop foreman, ppl from e autotrans co. came down for a final inspection b4 e car is put to e road test. Quite professional n responsible i wuld say. The drive reveals tat e autotrans was as gd as new n i was ensured tat all internal prts tat needs to be replaced (oil seals, clutch, filter, etc) r new. And warranty includes e valve body as well.
total damage=4k ringgit
Hi Pal!previa333 wrote:Finally, got mi ody back.
May I have the address? I think my gearbox got problem liao!
How long it actually takes? cos I think I might ask my friend to accompany me!
Rgds,
CS Goh
Speed thrills! But skills!
takes 3 days. will pm u e addresscsgoh wrote:Hi Pal!previa333 wrote:Finally, got mi ody back.
Rgds,
CS Goh
Thanks in advance!previa333 wrote:takes 3 days. will pm u e addresscsgoh wrote:Hi Pal!previa333 wrote:Finally, got mi ody back.
Rgds,
CS Goh
Re:
[quote="previa333"]Finally, got mi ody back.
total damage=4k ringgit[/quote
Can give me the address? Tq
