Is there a quick and easy DIY way to change the existing interior lights in my pre-FL Oddy RB1 to LED ones? Is it a simple plug-n-play kind of thing?
Also, I feel that my existing stock HID lights seem to me to be less white and becoming more yellow. My work colleague also commented that his also seems like that. Any others notice this? Anyone can advise on more brighter and whiter replacement bulbs especially the cost and any recommended shops.
Regards
Change interior lights to LED
Re: Change interior lights to LED
The interior lights can by pry open slowly by a sharp objects likes of the screwdrivers (advise to use a cloth between it so that it will be damage the clear plastic light cover).
However, pls note that the connector is the issue and when buying LED lights specify that it is for HONDA or purchase those with multiple adapter so that it can fit by plug and play. ... hope this helps..
HID lights - could it be the cover which I find nornally covered with dust and stain after several years of usage. Saw something that can clean off (the outside) in Autobacs last time but not sure if the interior side can be opened for cleaning...
abdulwz wrote:Is there a quick and easy DIY way to change the existing interior lights in my pre-FL Oddy RB1 to LED ones? Is it a simple plug-n-play kind of thing?
Regards
eagle0405 wrote:The interior lights can by pry open slowly by a sharp objects likes of the screwdrivers (advise to use a cloth between it so that it will be damage the clear plastic light cover).
Regards
Happen to see yr post n concerns.....interior light can be changed easily....led bulbs can be bought from any auto shops like autobac n etc....caution is autobac a bit ex....
HID need some expert...need contact, pm me....i did mine at a shop...reasonable price n 1 yr warranty given....btw, he also k do led interior light...cheaper...
Cheers!
Cheers!
