clay polish wax
You like your car sparkling and clean? Here is where U can get tips
YEN96
clay polish wax
Post by YEN96 » Fri Dec 04, 2009 7:53 am
wat is the difference in application of clay, polish and wax ?
eeee78
SHC Die Hard!!!
SHC Die Hard!!!
Post by eeee78 » Fri Dec 04, 2009 10:26 am
Google it! :lol:
TCSS Emperor!
讲鸟è¯
SS2000
10 000rpm Over Rev
10 000rpm Over Rev
Post by SS2000 » Wed Dec 09, 2009 11:46 pm
ask the professional shops who do it :lol:
goldclass.com.sg
Re: clay polish wax
Post by goldclass.com.sg » Sun Dec 13, 2009 8:04 pm
YEN96 wrote:wat is the difference in application of clay, polish and wax ?
Bro,
In professional detailing, both 'above' surface defects and 'below' surface defects must be removed in order to acheive a MAXIMUN shine. Below listed are a basic processes;
'Above' surface
- Claying is to remove contaminants that stick into your paint finish.
- Paint Cleaning is for removal of paint oxidation
'Below' Surface
- Polishing is to remove of swirls, scratches, marring, etc
This may help you to understand better --> http://goldclass.com.sg/knowledgecentre.php?opt=5&pg=1
Waxing
After you have jewelled out the car paint finish, you would need something to protect the shine. This is where you need to apply a coat of sealant or wax to lock-in the shine.
Hope this will help. :wink:
Taking Your Car Paintwork To The MAXIMUM POTENTIAL!
ydnaR
Post by ydnaR » Mon Dec 14, 2009 4:32 pm
Jewelling a paint to a perfect level is not an easy task.
At least a 3 stepper min imo..
Its good to live in a place where mainstream products are worth the dough.
The JDM gods blessed the minority.
goldclass.com.sg
Post by goldclass.com.sg » Mon Dec 14, 2009 8:09 pm
Perfection doesn't come cheap and it is not an easy task to achieve perfection. Rotary & DA machine coupled with different types of cutting & finishing Pads are required. Different cutting and finshing products are also to be used to combine as a 'Tag Team' with the pads use.
Below is a recent project which is very close to perfection;
ydnaR
Post by ydnaR » Wed Dec 16, 2009 2:38 am
No sun shots?
Imo good work doesn't always show from reflection shots.
No offence man.
You should show off your close to perfection in the bright sun, would look awesome i suppose,
Was the car wet sanded? Or it came orange peel free?
Come'on show us some process pics man.
Care to share what was used to jewel the paint?
I am still contemplating what pad to use. LC blue or black.
I have got my polish of choice already.
Cheers
Mugen Boi
Post by Mugen Boi » Wed Dec 16, 2009 10:13 pm
actually u'll need 2 c the car in person n frm a certain angle 2 c any in-perfections on the car itself...even if u look @ the car under the sun...u'll not notice anything n when u park in a shelter w/ a light over the car...u may notice some hairline scratches or dents u didn't notice in the 1st place :wink:
ydnaR
Post by ydnaR » Fri Dec 18, 2009 3:57 am
Mugen Boi: Paint correction dont remove dents and scratches that have gone through. And the sun is the best light source to spot swirls and holograms.
But so true, viewing the car in person is the best.
Cheers!
eeee78
SHC Die Hard!!!
SHC Die Hard!!!
Post by eeee78 » Fri Dec 18, 2009 9:06 am
Sun is the best light source to check for job done 8)
TCSS Emperor!
讲鸟è¯
K1@
Post by K1@ » Fri Dec 18, 2009 11:31 pm
Remember to put on your shades like this 8) during the inspection... :lol:
eeee78
SHC Die Hard!!!
SHC Die Hard!!!
Post by eeee78 » Sat Dec 19, 2009 10:04 pm
K1@ wrote:Remember to put on your shades like this 8) during the inspection... :lol:
Wear cap also..will be hot :lol:
TCSS Emperor!
讲鸟è¯
