CL7R vs CL7A suspension
Question time
How much lower is the R suspension vs the A suspension? Or are they of the same height?
I ask cos i want to buy.
It is obviously poisonous.... yet I chose to jump in....
Re: CL7R vs CL7A suspension
I don't think there is much of a difference in height - stiffness yes, height no. Why do you think most Euro R owners change the suspension??trugy wrote:Question time
I thought got lower a bit mah. Euro R owners want to change suspension becos they dun want lower a bit only, they want lower a lot loh.ml2spin wrote:I don't think there is much of a difference in height - stiffness yes, height no. Why do you think most Euro R owners change the suspension??trugy wrote:Question time
Like that explain can or not?
Got people offer me used one. I won't go buy new one for sure. But if no diff, then no buy lo.
- Yaloryalor
I am using D2 coilover for the past few months. So far so good!trugy wrote:I thought got lower a bit mah. Euro R owners want to change suspension becos they dun want lower a bit only, they want lower a lot loh.ml2spin wrote:I don't think there is much of a difference in height - stiffness yes, height no. Why do you think most Euro R owners change the suspension??trugy wrote:Question time
coilover expensive leh. Unless the stock one spoilt then no choice lo. heheYaloryalor wrote:I am using D2 coilover for the past few months. So far so good!trugy wrote:I thought got lower a bit mah. Euro R owners want to change suspension becos they dun want lower a bit only, they want lower a lot loh.ml2spin wrote: I don't think there is much of a difference in height - stiffness yes, height no. Why do you think most Euro R owners change the suspension??
I on R suspension before, the only different is, feel slightly harder than a thats all. The shocks are the same, only the springs differenttrugy wrote:Question time
Exactly same shock but diff springs??tckeong wrote:I on R suspension before, the only different is, feel slightly harder than a thats all. The shocks are the same, only the springs differenttrugy wrote:Question time
What a disappoointment haha
cl7r and cl7a suspension
Hi Guys,
Just to check, Euro R suspension can be used on Cl7a too??
Re: cl7r and cl7a suspension
djo1977 wrote:Hi Guys,
Yes, shock the same spring harder only
Modding a car is fun by going in part by part ...
the issue is remodding the same part again and again ....
Best part is no further upgrades then revert back to stock and then the butt feels shiok ....
Tried several coilover and most did not last over 1.5 years ....
Best i have STOCK .... (backside itchy 2 months change liao)
Next Best NEW Bilstein ... (last me 1 year and the guy at the rear feel like vomitting ... )
NEW BC BR (last me less than 1 year)
Tomei (4 months - second hand set)
Closest to stock is bilstein with comfort and handling ....
Remember to sevrice your coil ... to last it a bit longer ....
for me i dun bother ... i just sell it ....
3333
