old bird please help: eg6 odometer prob
Civic model year 1980 - 2000
hondavtec1
Post by hondavtec1 » Wed Nov 04, 2009 6:19 am
okie 2 scenerio . both got odo prob ,both have rsm
1st case : speedo not working (mati!!), rsm speed working. using powerfc - handheld speed function working . no checklite.
results:?
2nd case : speedo mostly not working , some times will become crazy swing up a bit but definately not accurate cos i travel highway , it show 10 -30 km/h..... rsm speed NOTHING also ....no powerfc used...ecu checklite will come out after drive a while ... then turn off .. drv again checklite come back ..
results:?
any help is greatly appreciated.
eg9. eg6.ek4.ek9.ef crx. ..ef9..eg2...dc2,...f20..c32b..k20 euroR..k20 fd2R..fn2R..prelude h22a..wah all nice honda cars i want.
Silver
Post by Silver » Wed Nov 04, 2009 10:05 am
Could be speed sensor spoiled liao... :) :)
uraco
Re: old bird please help: eg6 odometer prob
Post by uraco » Wed Nov 04, 2009 4:11 pm
hondavtec1 wrote:okie 2 scenerio . both got odo prob ,both have rsm
results: Speedo meter spoil(likely), connection loose(unlikely)
results: Speed sensor faulty, Socket plug to speed sensor loose or connection problem, Socket plug to speed sensor wet due to water splash
rellik28
Post by rellik28 » Thu Nov 05, 2009 8:27 pm
results:?
results:?
Its most prob ur wiring.. if speed sensor unit spoil, it won't be intermitten... it will all the way hay wire until no more speed indication...
cheers
EG6stanley
SHC Die Hard!!!
SHC Die Hard!!!
Post by EG6stanley » Sat Nov 07, 2009 11:45 pm
Silver wrote:Could be speed sensor spoiled liao... :) :)
Bingo... That happen to me once....
ST@NLEY(Choa Chu Kang)
hondavtec1
Post by hondavtec1 » Sun Nov 08, 2009 4:49 am
hi guys!
thx for your response! which scenerio is sensor spoilt???? is called vss rite? vehicle speed sensor :oops:
Hondamatic
Post by Hondamatic » Sun Nov 08, 2009 11:35 pm
results: speedo
results:? speed sensor. Can try to remove the sensor for cleaning. I tried that and so far no problem.
fernZ57
Post by fernZ57 » Mon Nov 09, 2009 9:54 pm
Don bother about the speed sensor 1st... Swop with another car meter and try.... if the swopped in one works meaning meter kaput... if also same then you try speed sensor.
I bought a speedsensor once tot that sensor spoil in the end its meter spoil.... So dun waste money first...
1000rpm. . . . . . . . . 5000rpm
vrrroomm. . . . . . . . VRRAAAAHHHHHHHH
Its the VTEC scream..........
