BBK Questions
turbobumblebee
BBK Questions
Post by turbobumblebee » Tue Sep 29, 2009 9:54 am
If it the set up is just with the front brake replaced, won't the distribution of the brake force be equal?
If both front and back brake kit are to be replaced, the rear disc must be smaller than the front disc? How much would be the right dimension or ratio?
AlanZ
Post by AlanZ » Tue Sep 29, 2009 2:48 pm
If front upsized and rear upsized, the distribution will be more even.
But ur rear caliper must have enuff bite oso.
I on 314mm front n rear 300mm. So far so good.
turbobumblebee
Post by turbobumblebee » Fri Oct 02, 2009 9:41 am
AlanZ wrote:If front upsized and rear upsized, the distribution will be more even.
When u say bite u r tokling abt the number of pots? Original one is one pot, so if change to 2 pot in front and bigger disc, then the rear cannot be 2pot? Or disc must be smaller?
