need help wit aircon , relay, temperature meter
tonyhawk2004
Post by tonyhawk2004 » Sun Sep 20, 2009 5:35 am
hi, i have 2 problems, first is that normally my temperature is slightly below half, but when i run about 90 to 100 on highway, my temperature shows way below, sometimes near COLD, when i slow down or slop my car, my temperature goes back to slightly below half. whats de problem? anyone can help me.. and 1 more problem is i just changed my aircon compresser and belt a month ago, but now there is something wrong with my a/c, sometimes de compresser will not work, when i press on de ac compresser clutch relay under my bonet, de compresser spins for a while and there is a wierd sound and it stops. izzit becoz of de wiring problem at de relay switches? pls help me. and just now out of curiousity i pull out de ac compressor clutch relay, the relay head seemed to dropped somewhere which i cnt find, and now when i on my ac, my idling drop by a lot and my voltage seemed decreasing when idling with ac aircon on. and after a while there is a loud noise which i dont know wad is it and i off my engine. what is de problem anyone can help me.. my number us 97812879. sry i m new. tks.
Silver
Post by Silver » Sun Sep 20, 2009 2:48 pm
Send to a workshop and get it check instead... The more you try fidding with it, the worse it gets... :) :)
