installing 5 lugs rims onto 4 lugs
Posted: Mon Aug 03, 2009 6:38 pm
by calvin13
Hi bros, as per my subject. Can anyone advise the solution to fix a 5 lug rim onto 4 lug? is there a spacer that can solve the problem?
Posted: Tue Aug 04, 2009 6:15 pm
by DIRT22
In short, no.
Posted: Wed Aug 05, 2009 12:32 pm
by 1.5bar
Depends on how much u wan e rims on ur car. Can be done but costly n time consuming.
Posted: Wed Aug 05, 2009 6:23 pm
by DIRT22
There is no way you can safely put a spacer conversion (even those that come with their own wheel studs) from 4 to 5 or vice versa, I wouldn't drive very hard in a vehicle that did that.
If you're talking about conversion ie. changing the 4-lug hubs to a 5-lug setup, however way you achieve it (be it change the entire arm assembly or just the hub+lugs ) then it's not longer 4-lugs liao, so 5-lug rim onto converted 5-lug hub is a no-brainer issue.
Of course provided correct PCD lah, later get some unusual European spec 104x5 that's it, find rims also can bang wall.
Posted: Thu Aug 06, 2009 12:43 pm
by garilee
for eg/ek can convert to dc2(98 onwards) or ek9. juz need to get change the front knuckles & rear hub. pcd 4X100 to pcd 5X114.3
Posted: Thu Aug 06, 2009 2:13 pm
by calvin13
hey thanks for all advice bro. I have tot of changing the hub but there's no hub that can fit for this car like dc2 onto eg.. sigh think i'll probably keep my rims at home and use it as coffee table.
