Audio
- jupiters319
Re: Audio
Try this setup:scratchyz wrote:Hi just want to check with you guys...anyone use the one din dvd player with the slide our screen...will it hit the stock HU on/off knob??
thanks
Re: Audio
how much does that cost?jupiters319 wrote:Try this setup:scratchyz wrote:Hi just want to check with you guys...anyone use the one din dvd player with the slide our screen...will it hit the stock HU on/off knob??
thanks
Treat a car like a human. It needs healthy diet, care and grooming, and most importantly, exercise.
- jupiters319
Re: Audio
Not sure, depend on audio shop. For Apline LCD panel cost around 200 plus & maybe 100 plus for the customization.calvin_ wrote:how much does that cost?jupiters319 wrote:Try this setup:scratchyz wrote:Hi just want to check with you guys...anyone use the one din dvd player with the slide our screen...will it hit the stock HU on/off knob??
thanks
- pReTeNd3R
Re: Audio
Like tt only the passenger can see only lehjupiters319 wrote:Not sure, depend on audio shop. For Apline LCD panel cost around 200 plus & maybe 100 plus for the customization.calvin_ wrote:how much does that cost?jupiters319 wrote: Try this setup:
Re: Audio
ya lo...pReTeNd3R wrote:Like tt only the passenger can see only lehjupiters319 wrote:Not sure, depend on audio shop. For Apline LCD panel cost around 200 plus & maybe 100 plus for the customization.calvin_ wrote:how much does that cost?
but then....how often the driver get the chance to c...
while waiting only ma...
Re: Audio
wont it be dangerous if the passenger airbag activated??jupiters319 wrote:Try this setup:scratchyz wrote:Hi just want to check with you guys...anyone use the one din dvd player with the slide our screen...will it hit the stock HU on/off knob??
thanks
no one have remove the stock hu and retain the digital aircon??would be nice if at that height...i find it quite low to fix 2 din below...
- jupiters319
Re: Audio
Alternative, DIY. http://www.caraudiomag.com/technical/ca ... index.htmlscratchyz wrote:Hi just want to check with you guys...anyone use the one din dvd player with the slide our screen...will it hit the stock HU on/off knob??
thanks
Re: Audio
wowjupiters319 wrote:Alternative, DIY. http://www.caraudiomag.com/technical/ca ... index.htmlscratchyz wrote:Hi just want to check with you guys...anyone use the one din dvd player with the slide our screen...will it hit the stock HU on/off knob??
thanks
this one is nice
Re: Audio
wa this one if got mai tu liao let's do it. not easy need to sand the monitor.adrianho wrote:wowjupiters319 wrote:Alternative, DIY. http://www.caraudiomag.com/technical/ca ... index.htmlscratchyz wrote:Hi just want to check with you guys...anyone use the one din dvd player with the slide our screen...will it hit the stock HU on/off knob??
thanks
this one is nice
Re: Audio
problem is my oc loves the compartment...calvin_ wrote:wa this one if got mai tu liao let's do it. not easy need to sand the monitor.adrianho wrote:wow
this one is nice
inside is full of her stuffs...hand cream la..etc
- Yaloryalor
Re: Audio
Very nice! I know some bros installing the LCD screen at this compartment. However, is it too low to see the screen? For CL7A, the gear knot is blocking the view for the rear passenger to see the screen?jupiters319 wrote:Alternative, DIY. http://www.caraudiomag.com/technical/ca ... index.htmlscratchyz wrote:Hi just want to check with you guys...anyone use the one din dvd player with the slide our screen...will it hit the stock HU on/off knob??
thanks
