If I'm not wrong, the full auto means it will regulate even the leg area. if you want, you can just press the up fan speed and that will on the aircon. Another way is to press the aircon mode till the arrow is pointing towards the head icon. that should do the trick.diablocivic55 wrote:ya tat is when u press the auto buttom right? when u depress tat buttom than the display will show FULLY AUTO. When u switch it off than it show only AUTO. So how to off tat AUTO? I found out tat my air con not so cold afterawhile..kobane wrote:from what i know, it simply means the aircon is in auto mode.diablocivic55 wrote:sry to highjack ur post ya mr TS.
Any guys here know wht is the auto display on the radio console for?
can tat be switch off? I mean auto tat dispaly beside the air con temp.
it regulates the aircon compressor depending on your cabin temp.
you should notice that in a hot day, it actually blasts quite high the moment you switch it on.
after awhile, it lowers to the normal fan speed.
Hope this helps...
