well recently for the past few month i`ve been looking around for a decent set of coilover within the range of $2k to $3k, with spring weight of 8 to 12 kg for lemonie, need to be able to adjust ride height, damping and preload.
from decent tien to funky priced drift racing V1. but after looking at s2ki it seem to point to buddyclub n+ spec, but it seems like in singapore its a little known brand and ppl who carries them are few, most just wanna sell but, after sales service like warranty seems to draw a blank look.
but somehow i found a shop who brings in buddyclub japan products and have proper 1 yr warranty on their coilovers, and the quotes are pretty decent too, best part they do bring in the 2 version found in japan, the BUDDYCLUB N+ SPEC and the BUDDYCLUB RACING SPEC, difference is the n+ use 10kg and 8kg rear spring and normal rubber urethene mounts whereas the racing spec uses 10kg front and rear, and pillowball top mounts, think the price diff is around $200.
but since this is a writeup/field report, i`ll just post some pic and first impression on the buddyclub n+ SPEC.
ordered the coilover and it took one week to arrive.
comes with 1 yr warranty
price includes installation and some fine tuning on ride height
and after my overseas trip to fraser hill, a call did comfirmed the arrival of the coilover.
woohoo buddies from jp
oooo nice colour too, its anodised red and the springs are powder coated blue.
the shock-body is constructed out of cadmium plated steel shock piston size of 40mm, and hardened chromoly 13mm shaft is used. all inside a single tube design.
some jap word which i dunno what it says
the urethene top mount , for comfort and more durability, but of course sacrifice some feel in steering precision
alu mounting, beautifully crafted, but i wish they are as thick as the motons, lol
buddy makes springs? hmmm, but good to see the rubber dust boot to keep performance in and crap out, more durability, woohoo.
look a light weight rear reinforcement bar from honda free!!!!
installation looks like a PITA, the left rear need to remove the fuel area to avoid scratching stuff up, and the rear bar was removed to have better acess to work on the removal of the old suspension which i say was pretty good for some B road blasting.
front mounted with the mini 15 click adjustable damping set to minimum to let the spring set in. but damping settings ranges from hard (+4kg/mm) to soft (-4kg/mm). at full soft it feels slightly softer than stock ap2 suspension
first impression, after they drop the car down, wahlau!!!!!!!!!!
front wheel clearance no finger, rear 1 finger gap looks like ready for track, but its a no go, after some adjustment, and the damping set to full soft, it feels slightly softer than stock ap2 suspension, and a quick drive around the area including going over some hump over and over again managed to settle the spring down, a quick measure show the whole car dropped 1cm all round, so up the car hoist for more adjustment, i set it up at 2 finger front and 2.5 finger rear, spring preload compressed from 20cm initially (uncompressed) to 19cm, then off i went for another drive around, ok feels better but the steering felt funny, must be the change in alignment and it had more camber than needed.initially running at 0.50 deg camber zero toe at front, rear 1.50 deg and 0.20deg toe in. but all that went out the window.
on the way back no weird kok kok kok sound or anything liddat, but going over hump will have a very soft hydralic hiss sound from the moving damper in the rear. but even the stock also have that sound so i`m not bothered by it.
immediately first prob encounted, rear damping adjustment is really a PITA, i need to tear out the panels, take out my spare tooks and spare tyre, pengz!!!!!!!!! in the end after 3 days of fiddling witht the damping from 12 click front and 8 rear, (damn hard) to 5 front rear zero( comfy but abit soft on the rear when thowing clutch in second gear will result in the car squatting abit) in the end i found a good compromise 10 front and rear 7, very nicely damped, i adjust and compressed the rear 8kg spring from 20cm to 18cm to have it slightly harder, and the wheel clearance rear is 11.5cm from lip of rim to the top of the wheel arch and front 11cm from lip of rim to the top of wheel arch, just nice without scrapping the cat up badly.
a quick run to kenny to have the car aligned back to my comfortable spec made the car nicer to drive and corner, less roll is noticed and road vibration is lessened, and the car no longer float on high speed mid corner bump. woohoo!!!!!! now i just need to make more front adjustment as i feel the front still roll but less liao(might need some atiffer arb in the front), front sag is 5.5 cm and rear is 7cm of sag height, just nice for B road blasting, i think it might be the 55S in front that make the car roll more due to the increased grip and the rear i`m using RE11, so it don understeer but provide some slight oversteer if needed when in the 7000rpm range, but nothing like the snap oversteer but the RE11 do let go ever so progressively, and a gentle easing off of the throttle will get back traction on the rear.
now problem i face is under cambered road and a full luggage and hard braking + cornering force, the roll of the car will make the re55s scrape the fender liner, i`m not going for more camber, but i was thinking if a beefier ARB will help. and i`m not going to go to stiffer coils, as i find it quite balanced liao, need more fine tuning, stay tuned for longer field test.
overall i give it a 8.5/10
value 10/10
adjustability 7/10 damn the rear damper adjusting knob location
quality 8.5/10, the aluminium bits do suffer some scratches after some adjustment, material might be soft.
after sales service 8/10 the shock rebuild kit can be brought if needed and rebuild be done in sg, but dunno how much it cost
