QN: What offset to choose for rims that flushes with fender?
I intend to upgrade my rims for my CL7R. Please advise the ideal offset for 17" 8JJ such that the rims will look inline with the fender? Because if the rims are not really flushed with the car body, for example, slightly on the inside, then it looks really ugly!
N also what tyre specs to choose for 17" 8JJ rims?
Appreciate all advise in advance!!
Cheers!!
Cheers!!
Rims Offset
Thanks for the infos..
The smaller the offset the inner the rims are right?
Please advise...
cos i do not intend to change my stock brakes so i wonder wat offset will look nice
Please advise...
Re: Rims Offset
The smaller the offset, the more protruding it will be.WilsonGoh79 wrote:Thanks for the infos..
Please advise...
+42 will do you fine.
Cheers!
- pReTeNd3R
Re: Rims Offset
The bigger the number the inner it'll go...meanin stock R rim is +55 so its inner....17" 8jj .+42/+43 w 225/45/R17 flash with fender
Re: Rims Offset
patcob wrote:The smaller the offset, the more protruding it will be.WilsonGoh79 wrote:Thanks for the infos..
Please advise...
Cheers!
Bro,
Will +38 be too protruding?
Re: Rims Offset
These applies to all rims design right?pReTeNd3R wrote:The bigger the number the inner it'll go...meanin stock R rim is +55 so its inner....17" 8jj .+42/+43 w 225/45/R17 flash with fender
Re: Rims Offset
Yes, it will be. It will be better for aftermarket BBK to clear rims.WilsonGoh79 wrote:patcob wrote:The smaller the offset, the more protruding it will be.WilsonGoh79 wrote:Thanks for the infos..
Please advise...
Cheers!
Bro,
Cheers!
- pReTeNd3R
Re: Rims Offset
yes applies to jap rims but taiwan rims the offset is anyhow....WilsonGoh79 wrote:These applies to all rims design right?pReTeNd3R wrote:The bigger the number the inner it'll go...meanin stock R rim is +55 so its inner....17" 8jj .+42/+43 w 225/45/R17 flash with fender
Re: Rims Offset
Will 8JJ +38 rub rear fender if car is lower down ?patcob wrote:Yes, it will be. It will be better for aftermarket BBK to clear rims.WilsonGoh79 wrote:patcob wrote: The smaller the offset, the more protruding it will be.
Cheers!
Bro,
Cheers!
I'm on the above setup. SSR type C-RS 17x8jj +42. Yes it protrudes out. How much? it is subjective. To me, it's an slightly not acceptable but i've left it alone for a long time liao till i got used to it liao...patcob wrote:Xianhong,xianhong wrote:Hi, Jus to check with the bros here using SSR typeC-rs - 17 x 7.5 +41 or 17 x 8 , will it hit the fender? because i think this is the only suitable spec for our car, as the next offset is +33
Take the 17X8jj will be ok, as long as the offset is within +40 - +42.
Cheers!!!!!
