I'm about to buy an EK4 SiR automatic...
- 1000rpm
hello all!
I'm almost set on this EK4..
http://www.sgcarmart.com/used_cars/info ... 22&DL=1001
As you can see it's an automatic...
I have a few questions:
1- Is expertise for internal wiring hard to come by? This car has a sunroof and electrically operated seats - in case they kaput, will replacing them be expensive or are parts/help easily and cheaply available?
2- The car has a black top engine which i assume is the B16A4 with 170 PS?
3- Should I want to convert to a manual transmission, what will the estimated cost be and what gearboxes can fit? Tried doing a search but i've come up short..paiseh..maybe a little help here pls! hehe
From what I've read, it seems that the stock ECU of the auto is compatible (?)
4- err.. don't have..hope to meet up with you guys soon should i succesfully purchase this one )
cheerio!
cheerio!
- 1000rpm
good choice.. previous owner prob an uncle.. super stock condition no mod at all.. so all the panels & clips shd be in good condition.. but you might want to do a full respray & colour change.. this colour really too uncle
btw you shd also check the engine & transmission condition before buying.. unless the previous owner has a full servicing record at KM.. drive down to your mechanic for a full checkup including chasis.. or insist that a STA evaluation report be produced at their cost..
EK Type-R wrote:good choice.. previous owner prob an uncle.. super stock condition no mod at all.. so all the panels & clips shd be in good condition.. but you might want to do a full respray & colour change.. this colour really too uncle
STA evluation is good but also best is u let your mech check the car if possible first ... my car before i bought was also brought to STA for a check ..
fancyTHIS
- 1000rpm
Looks like a good buy to me at that price...
Whatever you need to plonk in afterwards to bring the car up to shape should not cause too much suffering since the depr is so low.
Car doesn't seem to have been abused in its life.
If no evidence of major accident repairs turn up in your STA inspection then you should jump on it.
I'm sure all of us here paid hella lot more for our EK4A..
How hard can it be?
- EK4 (Birdho)
Re: I'm about to buy an EK4 SiR automatic...
1) no comment.nikolaiski wrote:hello all!
cheerio!
2) you will not get 170bhp for a EK4 auto, if this is a stick engine
you are getting only 155bhp, on wheell , it iwll be much lower.
only the manuel EK4 is doing stock at 170bhp.
3) not able to help u on the convert form auto to manuel, but the EUC need to change, and not just a plug and play, a lot of small details need to be done which will cost a bomb, a better suggestion is get a manuel on the market, pay slightly more, and you will hv almost everything in order.
just my own view as i use to own a EK4A
- EK4 (Birdho)
Gil!!EK4 (Birdho) wrote:maybe the price gone down, do you have the workshop name that can help on the convert and charge only 2 to 3 k>?stylomilo wrote:wow, cheap hor... another 2-3k to convert manual and its only slightly over 30k for a EK4... sounds like a damn good buy!
Nong time no see!!!
3K+ sing actually can do, just that you would be skipping a few steps and not getting a proper honest-to-god properly done conversion....if you're not particular about things, in a pinch still can make it work, but mostly with junkyard stock parts albiet reconditioned (if at all).....
In a pinch, the EK4A ECU can be re-used, if no alternative is available, as can the dash with the PRND4D321 display....take out the auto-trans module/s, punch out the firewall holes and the trans tunnel holes, cover (weld) back the resultant leftover holes, source a set of shifter and shifter linkages, pedal linkages, the requisite clutch and slave assemblies including pumps, of course the gearbox (hopefully comes with clutch and flywheel) and other smaller parts..... There's alot of labour involved, may not be everyone's cup of tea....
Given the traffic condition nowadays, it might be a smarter move to leave it automatic! The EK4A ain't no slouch too ya know.....
- 1000rpm
Hello DIRT22!
Is that your EK at Sepang? I might've taken a few pictures of your car if you've attended SGtrackies' track days or time attacks in the past where there's only ONE black EK4 running around..if i'm not wrong that is...heh
I guess the idea of an engine that revs to 7000+ rpm that is an automatic is just a little wierd to me, especially if it's a honda..you know ..itchy backside n all..heh
but in the end I might just keep the car running as it is until I come around to buying a whole Bxx block (haven't thought of it yet...) but I guess that'll be in the last thing after all the other chassis upgrades in the future..IF i even get around to doing those..no point doing a slapdash job for a very capable-running car )
As a moot point...does Hayden or some other brand make auto-tranny coolers for the EK4A? I would want to be investing in those as I've ruined my old car's auto-box before by hard-lining it without the proper cooling..heh
- EK4 (Birdho)
hi joeDIRT22 wrote:Gil!!EK4 (Birdho) wrote:maybe the price gone down, do you have the workshop name that can help on the convert and charge only 2 to 3 k>?stylomilo wrote:wow, cheap hor... another 2-3k to convert manual and its only slightly over 30k for a EK4... sounds like a damn good buy!
Nong time no see!!!
really been a long time sice we catch up,
when this thread came by, i was thinking,
where is joe, he is the best person that can advise on all the details.
a friend did that and guess wat, his gearbox fell off when he was driviing along pie. all in all, it took him close to 3 months to get all settled, as some parts not avialble and need to import from japan etc..
i think the work shop plays a part in this case, but soem work shop just want to earn mony only.
anything Boleh.. i
anyway, hope to be able to attend meet up and catch up with you soon.
