car vibrate when off engine
Posted: Wed May 06, 2009 10:40 pm
by sibeisian
after a long drive, when right after i off my engine, my car will vibrate quite significantly.
don't know where its comign from, but the vibration seems to sync with the exhaust sound.
is this normal for a 1 year old car?
Posted: Thu May 07, 2009 6:04 am
by Cougar_23
car still under warranty ? yes, go back to your workshop and tell them (dun waste money mah).
believe its something to do with the belting (either too tight or loose) => i might be wrong.
being a 1 yr old car, more or less already "run in"...did u change anything recently too?
Posted: Thu May 07, 2009 6:06 am
by Efhatch
if car under warrantly. you are done.
Posted: Wed May 13, 2009 6:41 pm
by sibeisian
i went KM liao, but they said its normal for some vibration when cut off engine leh.
Any comments?
Posted: Wed May 13, 2009 9:34 pm
by Efhatch
right now i understand what you means, and yeah it's normal, i have worked on K20s EP3s and FN2s cars and those engines have a lot vibrate comparing with another cars/engines. what you can do is to buy a engine damper, that will avoid that problem.
Posted: Thu May 14, 2009 9:39 am
by sibeisian
will it get worse over time?
Posted: Fri May 15, 2009 1:44 am
by Efhatch
very likely, even you can get problem with your header. i recommend get one engine damper, it isnt so expensive. and works great.
