CL7A part Nos
CL7A part Nos
Some part number for the A bros. collected from what i changed over the years. Price est from Tanly/Thian Seng
1. Compressor Belt - 38920-RBA-003 - $30
2. Fuel Filter - 16010-SEA-000 - $45
3. Rear Engine mounting - 50810-SDA-A02 - $115
4. Transmission upper mount - 20870-SEA-E01 - $55
5. Front engine mounting - 50830-SDA-A03 - $120
6. Water pump - 19200-RFE-003 - $105
7. HAMP oil filter - 15400-PLC-505 - $7
8. ATF filter25430-PLR-003 - $20
9. Side engine mounting - 50820-SEA-001 - $85
10. Right front door rubber - 72325-SEA-003 - $60
11. Left front door rubber - 72365-SEA-003 - $60
12. Stock ARB bushing - 52306-SDA-A01 - $10
13. Driver door actuator - 72115-SDA-A01 - $110
14. Left front door actuator - 42155-SDA-A11 - $120
Prices only as a guide. Bros who have more pls add in
chasis.. ?
Thanks for sharing... T Seng told me chasis# is all they need to find the parts for the car... so i just tell TS what i need and they told me their suppliers in Japan look up the Part# from their DB to locate the correct parts. makes it easier for me..
- Gingerfish
- Gingerfish
- Gingerfish
Felt Cheated
BASKET !!
Kenna CON and carrot head by CHUAN LEE HIN !!
They said i reached 100k.
Need change fuel filter.. If not car will have problem.
Price tag for fuel Filter is $160 per piece.
Whereas just saw from the post.. only $45 from Thian Seng !!
Damnit !! Bunch of con man.. this will be a last time visit to them !!
If they waana earn.. 20 to 30 bucks .. understand.. but wow.. a whopping $115 bucks !
Felt so cheated by them !!
CL7 bulb sizes (taken from Philips auto application guide)
please feel free to correct if I got it wrong.
FRONT:
Low beam (HID) = D2S
Low beam (halogen) = HB4
High beam = HB3
Side/parking = W5W
Indicator = W21W
Fog lamps = H11
REAR:
Brake = W21/5W
Tail = W5W
Reverse = W21W
Indicator = W21W
Number plate = W5W
http://www.lighting.philips.com/in_en/c ... ng&lang=en
FRONT:
High beam = HB3
Side/parking = W5W
Indicator = W21W
Fog lamps = H11
REAR:
Brake = W21/5W
Tail = W5W
Reverse = W21W
Indicator = W21W
Number plate = W5W
Re: CL7A part Nos
Just for sharing. Some parts same as the bro above but my prices slightly more expensive from Thian Seng. Can bargain a bit, but i not a good bargainer.
Left rear door actuator - 72655-SEA-G11 $100
Fuel Filter - 16010-SEA-010 $50
Tensioner (informed that it is same as 2.0 Civic) 31170-PNA-023 $110
Fan Belt - 38920-RBA-003 $65
Oil Filter - $10
Oil Filter - $10
