Honda Fit/Jazz Vehicle Identification Number (VIN) Codes
chaicka
Post by chaicka » Mon Nov 03, 2008 10:17 pm
Code: Select all
 JHM    GE8   7   2   *   9   S   2000001
|-a-|  |-b-| |c| |d| |e| |f| |g| |---h---|
a is Manufacturer, Make and Type of Vehicle
JHM stands for Honda Motor Co., Ltd. Honda passenger vehicle
b is Line, Body, and Engine Type
GE6 stands for Jazz/Fit, L13A?
GE8 stands for Jazz/Fit, L15A7
c is Body Type and Transmission Type
7 stands for 4-door hatchback/5-speed manual
8 stands for 4-door hatchback/5-speed automatic
d is Vehicle Grade/Series
3 stands for 1.3 G model :?:
4 stands for 1.3 LX model :?:
5 stands for 1.5 S model
e is Checksum Digit
f is Model Year
9 stands for 2009
g is Factory Code
S stands for Suzuka factory in Japan
h is Serial Number
000001-onwards- stands for USA models
200001-onwards- stands for Singapore models
800001-onwards- stands for Canada models
icejazz
Fit/Jazz Moderator
Fit/Jazz Moderator
Post by icejazz » Mon Nov 03, 2008 10:20 pm
gd infor..sticky liao
Image Image
mohgui
Post by mohgui » Tue Nov 11, 2008 9:54 am
hey... thanks! but where can we find this info? which part of the car can we see this?
wilswong
Post by wilswong » Tue Nov 11, 2008 2:31 pm
Physical-
Jazz: Bottom left corner of the left door. There's a steel label plate.
Online-
Go to e-Services of www.onemotoring.com.sg (please use IE)
Click around you can also see the VIN number.
david325
Re: Honda Fit/Jazz Vehicle Identification Number (VIN) Codes
Post by david325 » Wed Nov 12, 2008 2:38 pm
Code: Select all
5 stands for 1.5 S model 1.3 model too
e is Checksum Digit
f is Model Year
9 stands for 2009
g is Factory Code
h is Serial Number
hbo31
Post by hbo31 » Sun Nov 23, 2008 7:53 pm
david325 wrote:
Code: Select all
e is Checksum Digit
f is Model Year
9 stands for 2009
g is Factory Code
h is Serial Number
For "a",is there any other than JHM???
konstrain
Post by konstrain » Mon Mar 15, 2010 12:59 pm
is there a way to find the vin code on the car?
wilswong
Post by wilswong » Sun Apr 11, 2010 2:04 pm
konstrain wrote:is there a way to find the vin code on the car?
Bro, see my post....already give instructions where to find it.
Russell123
Post by Russell123 » Fri Apr 23, 2010 5:31 pm
wilswong your post is really very informatics and full of knowledge its help me much.
thanks for your post
kokwm
Post by kokwm » Mon May 03, 2010 9:40 pm
Fyi, this is an example of VIN code for Thai manufactured Jazz.
MRHGE68509P02####
MRH -> Honda Thailand
Australian Jazzes are MIT as can be seen from Redbook AU (http://www.redbook.com.au), the market value site for all AU cars.
wilswong
Post by wilswong » Tue May 04, 2010 2:35 pm
Russell123 wrote:wilswong your post is really very informatics and full of knowledge its help me much.
this info given by Chaicka...he should get the praise.
wilswong
Post by wilswong » Tue May 04, 2010 2:38 pm
kokwm wrote:Fyi, this is an example of VIN code for Thai manufactured Jazz.
MRHGE68509P02####
Bro, check this out
http://www.redbook.com.au/used-cars/det ... 8642D6F04A
it is MRH as well. Thai made Jazz
konstrain
Post by konstrain » Mon Jun 07, 2010 3:45 pm
[quote="wilswong"][quote="konstrain"]is there a way to find the vin code on the car?[/quote]
Bro, see my post....already give instructions where to find it.[/quote]
thanks bro, but i still can't find it.. lol
mine's a ge6 fit
either physically or online also dun have
wilswong
Post by wilswong » Wed Jun 09, 2010 11:42 pm
mine's a ge6 fit
If LTA online do not have it, then seriously something is not right as the car should have its VIN number to match to the Registration number or else anyone suka suka can change plates with any cars.
konstrain
Post by konstrain » Tue Jun 29, 2010 6:22 pm
[quote="wilswong"][quote="konstrain"][quote="wilswong"][quote="konstrain"]is there a way to find the vin code on the car?[/quote]
mine's a ge6 fit
either physically or online also dun have[/quote]
If LTA online do not have it, then seriously something is not right as the car should have its VIN number to match to the Registration number or else anyone suka suka can change plates with any cars.[/quote]
wow that sound bad!
there's something called engine no and chassis no in the LTA online portal.
but it doesn't match the VIN format. @_@
is my fit considered pirated, or something wrong with the car?
