Perfect Way to run in yr new car?
wilswong
Post by wilswong » Tue Sep 23, 2008 1:44 am
metank..not just first car...ALL the cars you are going to own...no point spoil engine then saddle with a hefty repair bill that insurance need to pay and you pay higher premiums also...
kriegs
Post by kriegs » Tue Sep 23, 2008 12:28 pm
wilswong wrote:haaaa....
baby virgin spinster...so long do it in a systematic way will prolong the engine's life...
rev slowly to max 3K let go max again let go for first 1-2K can already.
What you guys say...Kah give w40 engine oil...perhaps stick with it until I go change oil at 5K mark?
My old jazz, was on mineral for 1st 1K and 5K servicing. shld be doing the same for GE.
10 years of Jazz - GD1 to GE8
icejazz
Fit/Jazz Moderator
Fit/Jazz Moderator
Post by icejazz » Tue Sep 23, 2008 12:38 pm
u forgot to tell them that after 5k servicing... u service ur car every 20k.. :twisted:
Image Image
wilswong
Post by wilswong » Tue Sep 23, 2008 3:05 pm
dunno what the servicing give should be mineral...5K still mineral? FC how?
20K per servicing? wah...so long ah...sure boh?
kriegs
Post by kriegs » Tue Sep 23, 2008 4:16 pm
mineral oil dun last so long, probably max is a few Ks of mileage. Then have to change.
wilswong
Post by wilswong » Tue Sep 23, 2008 6:11 pm
kriegs wrote:
wilswong wrote:
kriegs wrote: My old jazz, was on mineral for 1st 1K and 5K servicing. shld be doing the same for GE.
that means after 5K will be synthetic liao lah...then can last to 20K mah...
haaa....save servicing money.
DollSecrets
Post by DollSecrets » Tue Sep 23, 2008 7:32 pm
I don't get it... mineral? Sorry, need so help in explanation here. Thanks!
VENUES – Singapore 1st Ever Streets with Treats Directory!
Visit us at www.VenuesDirectory.sg
icejazz
Fit/Jazz Moderator
Fit/Jazz Moderator
Post by icejazz » Tue Sep 23, 2008 8:26 pm
2 types available... synthetic (used up to 10k plus) or mineral (use for about 5k must change)
for me.. after 1k servicing i change to synthetic straight. lazy to go for 5k servicing...
Image Image
Metank
Post by Metank » Tue Sep 23, 2008 11:23 pm
wilswong wrote:metank..not just first car...ALL the cars you are going to own...no point spoil engine then saddle with a hefty repair bill that insurance need to pay and you pay higher premiums also...
u make a point there. anyway what's with all this mineral oil. what semi syn and full syn. Pardon me, am totally lost. :lol:
wilswong
Post by wilswong » Tue Sep 23, 2008 11:47 pm
super summary
mineral as name suggest is close to 100% real oil
semi synthetic is about half fossil fuel based oil and the other half is chemical based
fully synthetic - fully chem based
Metank
Post by Metank » Wed Sep 24, 2008 12:44 am
aight. But, when to change what? sounds confusing. lol. bear with me. totally new.
wilswong
Post by wilswong » Wed Sep 24, 2008 2:49 am
1K - mineral
5K - synthetic(according to ICE)...some kiasi one...semi synthetic
10K - synthetic
there are also 'thickness'...thicker = more protection
w50 - thickest means engine more sluggish but max protection
w40 - in between the extremes (Kah uses this thickness)
w30 - thinnest...engine response good, protection not as good.
I think there are better brothers out there who can give a better intro.
Wonder where Chaicka go to...
kriegs
Post by kriegs » Wed Sep 24, 2008 5:51 pm
using mineral is to 'wear off' the engine... and technically make it run at it best. Cos when it seat in the ship, residue may form inside the engine... so got to make it 'work' harder to 'clean' off these residue...
But this is all subjective... easiest is refer to the servicing maunal
cyrix1976
10 000rpm Over Rev
10 000rpm Over Rev
Post by cyrix1976 » Thu Sep 25, 2008 3:36 pm
Basically you just drive normally, increase your speed graually and increase RPM until 4k to 5k. After 1k, send for full servicing including change of gearbox oil so as to ensure your vehicle is in good condition. Spend a littel more.
Reason why you can drive up to 140km/h and rpm at 4k is, before you drive your car, engine had already been stress before mounted on your car body and dealer or supplier had already drive your vehicle around, from pt a to pt b or even to inspection centre for inspection.
Honda EG 4 Dr 2003-2004
Honda EG 4 Dr 2006-2009
Honda DC5 GSR 2009-201_
wpyeo
SHC Die Hard!!!
SHC Die Hard!!!
Post by wpyeo » Thu Sep 25, 2008 7:17 pm
cyrix1976 wrote:Basically you just drive normally, increase your speed graually and increase RPM until 4k to 5k. After 1k, send for full servicing including change of gearbox oil so as to ensure your vehicle is in good condition. Spend a littel more.
correct.. the key point is not to sudden rev up ur RPM... just slowly gradually increase speed/rpm... else is just normal driving patterns, and let ur car understand ur driving habit as well! :D
