some modifications tips to share ard..
fitter_1688
Post by fitter_1688 » Fri May 30, 2008 3:35 pm
Air intake, air filter
Air intake(throttle body & manifold)
For our stock Fit 08, I’ve yet to measure the diameter of the throttle body and manifold, if u wan to have a better response, change to a 1.5 throttle body instead of boring the stock throttle body, as we double bore it but the butterfly valve is still the original diameter, it may cause ur idling to be erratic and unstable, plus if u bore it too much the throttle body will become fragile, and if u tighten the air filter too tightly u may damage the throttle body. If u change the throttle body, it would be advisable to bore ur manifold too, if not u won feel the gain and effect, by doing both u will feel that ur engine response would be better den before.
Air filter
For our stock engine, our stock air box is actually good enough as its covered up and won be taking in hot air compared to open pod, I would recommend to change the paper filter to a K&N or Simota drop in filter, by changing dis u will find a slight improvement on ur FC and response, as for those who wan to have a high air flow intake, u may consider open pod, but pls ensure u do up a proper heat shield to prevent hot air getting in, as we know cold air creates better combustion, open pod will let u feel smoother during ur high end but u tends to suffer a little on ur low end and slight increase on ur FC.
Exhaust
Extractor
For stock, we’re using a 4-2-1 extractor, but due to the diameter we may feel restrictive at times, so the best is to change it to a aftermarket extractor, there are 2 kinds currently namely the 4-2-1 and the 4-1, 4-2-1 give u a better low to mid end but not as good in the high end compared to the 4-1 and vice versa the 4-1 give u a good high end but u will suffer during ur low to mid end range, for my personal opinion a 4-2-1 is a better option compare to a 4-1 as we are mostly driving in city, if u were to use a 4-1 extractor u may feel sluggish during ur move off and definitely suffer on ur pick up and FC.
Cat
After the extractor shall be our cat, the most common way to straight thru ur exos is to knock thru ur cat, or u may change to a aftermarket high flow cat, or even remove the cat, but as our car are auto, it will actually slower down our pick up and cause our FC to increase, unless u’re looking for more high end power I would recommend u to knock thru half the cat, u will suffer a little on ur pick up and FC but not as bad as knocking thru the whole cat or change to a high flow cat.
Mid pipe
After our cat shall be the mid pipe, haven got the chance to measure our mid pipe, but it should be quite small, if I’m correct, we can change to a bigger diameter mid pipe, like 1.75â€
wilswong
Post by wilswong » Fri May 30, 2008 4:06 pm
wah good round up!
already book marked.
fitter_1688
Post by fitter_1688 » Fri May 30, 2008 4:09 pm
wilswong wrote:wah good round up!
don like that say lei...
:oops:
FIT'08 going off soon..
Toyota Hilux SW4(fortuner) oct'08 to ???
kriegs
Post by kriegs » Fri May 30, 2008 5:37 pm
poisonous list... :twisted:
10 years of Jazz - GD1 to GE8
euphosis
Post by euphosis » Fri May 30, 2008 5:44 pm
:oops:
wahh...not bad...in my guide book liao... hmm how about engine oil?? any advise which is good?
icejazz
Fit/Jazz Moderator
Fit/Jazz Moderator
Post by icejazz » Fri May 30, 2008 9:47 pm
good infor.. sticky it up :)
Image Image
chrisss
Post by chrisss » Sat May 31, 2008 12:57 am
bro i got question.
our stock manifold is 4-1 or 4-2-1?
seems like 4-1 to me and Fong Kim also said its 4-1.
please advise
fitter_1688
Post by fitter_1688 » Sat May 31, 2008 8:48 pm
chrisss wrote:bro i got question.
please advise
if i'm not wrong shall be 4-2-1, but i must go dismantle mine and check first..
:wink:
fitter_1688
Post by fitter_1688 » Sat May 31, 2008 8:50 pm
icejazz wrote:good infor.. sticky it up :)
thanks bro, hope u don mind my simple knowlegde regarding modification, haha..
:wink:
icejazz
Fit/Jazz Moderator
Fit/Jazz Moderator
Post by icejazz » Sat May 31, 2008 9:33 pm
:wink:
u too humble.. :)
we must share knowledge aka poison :twisted:
Image Image
allianimus
Post by allianimus » Sun Jun 01, 2008 4:37 pm
I would like to know if emanage got void warranty?
good post! im poisoned..
wilswong
Post by wilswong » Sun Jun 01, 2008 5:19 pm
Maybe fitter can review the list again when the Jazz comes...might be different.
fitter_1688
Post by fitter_1688 » Sun Jun 01, 2008 7:31 pm
allianimus wrote:I would like to know if emanage got void warranty?
nope, cos its onli taping on to ur ecu harness, if ur car got problem and wanna claim warrenty jus remove the e-manage will do liao, cheers..
:wink:
fitter_1688
Post by fitter_1688 » Sun Jun 01, 2008 7:32 pm
wilswong wrote:Maybe fitter can review the list again when the Jazz comes...might be different.
fit jazz engine are the same mah, like the previous fit jazz are actually using the same spec except for the displacement, like CITY, also same spec and horse execpt for the displacement..
cheers..
:wink:
allianimus
Post by allianimus » Mon Jun 02, 2008 2:32 am
:wink:
Thats great! Where is a good place to buy and tune? what is the price like?
