Fit / Jazz model year 2002 - 2007
takano
Post
by takano » Tue Mar 23, 2004 8:33 pm
kriegs wrote:Fit - fuel lid is cable operated like the Civic’s
Jazz - fuel lid is not locked, and got to use key to open the cap.
Fit uses single 2 way windscreen washer fixed on the bonnet
Jazz is using double mist spray on the plastic piece between bonnet and windscreen.
No leh fit and jazz both the same leh...the windscreen washer are fixed on the plastic piece, not the bonnet.
xRay
Post
by xRay » Tue Mar 23, 2004 9:55 pm
takano wrote:kriegs wrote:Fit - fuel lid is cable operated like the Civic’s
depends... the older fit are wif only 1 nozzle... only the later batch comes in double nozzle...
tortoisenette
Post
by tortoisenette » Tue Mar 23, 2004 10:35 pm
well, fit comes in too many versions liao....
this topic have been rised a lot of times .. haha... i remember sometime back last yr, i posted on Fit version W, A, Y... anybody remember bo? hehe
no more ings... just a simple type s hello kitty~ meow..
cruzzyrider
Post
by cruzzyrider » Wed Mar 24, 2004 11:32 am
will be very interesting if there is a 4WD Fit in town............
takano
Post
by takano » Wed Mar 24, 2004 11:45 am
xRay wrote:takano wrote:kriegs wrote:Fit - fuel lid is cable operated like the Civic’s
Ya lor........... my one only got 1 nozzle
SR20DET
Post
by SR20DET » Thu Mar 25, 2004 8:43 am
xRay wrote:let me recall... i'm comparing fit 1.3 and jazz 1.4
both idsi engine but...
jazz - 83bhp
fit - 86bhp (different ecu programming)
jazz - side signal indicator
fit - no side signal indicator
jazz - rear seats only 1 angle
fit - rear seats 2 angles
jazz - front seat no lever at shoulder to shift the seat forward
fit - lever at shoulder to shift the seat forward
jazz - max speed on speedo is 220km/h
fit - max speed on speedo is 180km/h
jazz - master control for all door lock at the driver door
fit - to lock all door, need to push the lock down
jazz - air con is fitted locally
fit - air con fitted in japan
jazz - antenna in the centre of the roof
fit - at the right side
jazz - no bonnet and firewall insulator
fit - factory fitted insulator at the bonnet and firewall
jazz - immobiliser key
fit - no such function
jazz - both sunvisor comes wif mirror
fit - only the driver side has the mirror
jazz - front brake calipers are bigger
fit - smaller
jazz - aftermarket radio given
fit - integrated sound system, freq not tuned to rx local station needs to install FM modulator
jazz - comes wif mug like ash tray/container
fit - cig jack comes wif cover
jazz - when reverse gear engaged, no sound
fit - beeping sound when reverse gear is engaged
jazz - front seats cannot fold all the way down and flush wif the rear seats
fit - can bring down the front seats (w/o headrest) and flush wif the rear seats... machiam a bed...
jazz - horns are at the left side
fit - horns in the centre
think tat's abt all i can recall... maybe the rest can add those i've forgotten??
Thanks - Any comments for the 0-100 timing for a jazz and the top speed?
xRay
Post
by xRay » Thu Mar 25, 2004 11:47 am
max speed for 1.3... both jazz and fit... is ard 160km/h...
0-100 dash... never done b4....
swaqq
Post
by swaqq » Thu Mar 25, 2004 3:31 pm
From the previous Torque magazine
Fit has a 2L i-VTEC engine
Jazz boh
HAHAHAHA
blueart
Post
by blueart » Thu Mar 25, 2004 8:05 pm
xRay wrote:max speed for 1.3... both jazz and fit... is ard 160km/h...
I read in some car magazine that 0-100 dash is:
Jazz Manual - 12.0 sec
Jazz/Fit CVT - 13.0 sec
...ming4 li3 you3 shi2 zong1 xu1 you3
ming4 li3 wu2 shi2 mo4 qiang2 qiu2...
BB88WA
Post
by BB88WA » Tue Mar 30, 2004 2:48 pm
any one notice Fit 1.5 has rear fog lights?
I notice one fit on ECP 2 nights ago with the fog light turned on. hmmmm...
whizzed
Post
by whizzed » Sun Apr 04, 2004 8:42 pm
jazz - 83bhp
fit - smaller
techo21
Post
by techo21 » Sun Apr 04, 2004 9:15 pm
0-100 tested liao...12 sec with L mode.
0-100 tested oso..but not acurate as i was going a little slope 14s with S mode.
going to do some more testing..hehehe
Drive HONDA to realise your DREAMS
Dreamer
Post
by Dreamer » Tue Apr 06, 2004 10:35 am
jazz - 83bhp
fit - smaller
So in ur point of view, jazz or fit is better? How abt value wise?
Thx
xRay
Post
by xRay » Tue Apr 06, 2004 11:54 am
difficult to ans yr qn... fit is cheaper but doesn't have full support in terms of warranty... jazz is the opp... it all depends on wat entice u... for me, i chose fit cos it's JDM spec...
wish9963
- Idling
Post
by wish9963 » Tue Apr 06, 2004 9:48 pm
xRay wrote:difficult to ans yr qn... fit is cheaper but doesn't have full support in terms of warranty... jazz is the opp... it all depends on wat entice u... for me, i chose fit cos it's JDM spec...
Hi there,
I had a remark from one of the PI saying that 1.5 Fit gear box is too weak for the Vtec engine is it true?
