Difference bet honda Fit / Honda Jazz
Fit / Jazz model year 2002 - 2007
SR20DET
Post by SR20DET » Tue Mar 23, 2004 12:37 pm
hi guys,
Juz booked a Red jazz..Want to kw the diff bet. jazz and fit ( performance wise n look wise) thanks
xRay
Post by xRay » Tue Mar 23, 2004 12:59 pm
let me recall... i'm comparing fit 1.3 and jazz 1.4
both idsi engine but...
jazz - 83bhp
fit - 86bhp (different ecu programming)
jazz - side signal indicator
fit - no side signal indicator
jazz - rear seats only 1 angle
fit - rear seats 2 angles
jazz - front seat no lever at shoulder to shift the seat forward
fit - lever at shoulder to shift the seat forward
jazz - max speed on speedo is 220km/h
fit - max speed on speedo is 180km/h
jazz - master control for all door lock at the driver door
fit - to lock all door, need to push the lock down
jazz - air con is fitted locally
fit - air con fitted in japan
jazz - antenna in the centre of the roof
fit - at the right side
jazz - no bonnet and firewall insulator
fit - factory fitted insulator at the bonnet and firewall
jazz - immobiliser key
fit - no such function
jazz - both sunvisor comes wif mirror
fit - only the driver side has the mirror
jazz - front brake calipers are bigger
fit - smaller
jazz - aftermarket radio given
fit - integrated sound system, freq not tuned to rx local station needs to install FM modulator
jazz - comes wif mug like ash tray/container
fit - cig jack comes wif cover
jazz - when reverse gear engaged, no sound
fit - beeping sound when reverse gear is engaged
jazz - front seats cannot fold all the way down and flush wif the rear seats
fit - can bring down the front seats (w/o headrest) and flush wif the rear seats... machiam a bed...
jazz - horns are at the left side
fit - horns in the centre
think tat's abt all i can recall... maybe the rest can add those i've forgotten??
cruzzyrider
Post by cruzzyrider » Tue Mar 23, 2004 1:11 pm
xRay wrote:let me recall... i'm comparing fit 1.3 and jazz 1.4
jazz - 83bhp
fit - smaller
1 more point to add
Jazz - factory fitted rear wheel arc inner fender cover(lower portion)
Fit - dosen't come wif it
Crush79
Diff btw jazz and fit
Post by Crush79 » Tue Mar 23, 2004 1:23 pm
If i am not wrong, Jazz front seat can be pushed further back for long legged drivers. Fit one is not able to. Correct me if i am wrong.
Crush79
Post by Crush79 » Tue Mar 23, 2004 1:24 pm
deanlim
Senior Moderator
Senior Moderator
Post by deanlim » Tue Mar 23, 2004 1:26 pm
jazz - 83bhp
fit - smaller
1 more point to add
another point to add
Jazz - manual transmission option
Fit - doesn't have
kriegs
Post by kriegs » Tue Mar 23, 2004 3:28 pm
Fit - fuel lid is cable operated like the Civic’s
Jazz - fuel lid is not locked, and got to use key to open the cap.
Fit uses single 2 way windscreen washer fixed on the bonnet
Jazz is using double mist spray on the plastic piece between bonnet and windscreen.
10 years of Jazz - GD1 to GE8
S4TYPE_R
Post by S4TYPE_R » Tue Mar 23, 2004 3:37 pm
All right, keep them coming... we can use this thread as a sticky for newbies.
Mod VTECian, cho kang hor!!
lala
front seat flush wif the rear..........
Post by lala » Tue Mar 23, 2004 3:51 pm
jazz - 83bhp
fit - smaller
bro can u teach me hw to flush the front seat wif the rear seat (machiam like a bed) ......i m nt sure hw to do it !! i hav try many times bt still dunno hw to do it ! :roll:
thanks .......if u dun mind gv me a call at 91095440. :roll:
VTECian
Forum Administrator
Forum Administrator
Post by VTECian » Tue Mar 23, 2004 3:56 pm
S4TYPE_R wrote:All right, keep them coming... we can use this thread as a sticky for newbies.
Wah, mod vtecian is being kept very busy! Traffic here is very heavy!!! #-o
Good thread, will add a sticky. Thanks!
Image Image
xRay
Re: front seat flush wif the rear..........
Post by xRay » Tue Mar 23, 2004 4:03 pm
lala wrote:bro can u teach me hw to flush the front seat wif the rear seat (machiam like a bed) ......i m nt sure hw to do it !! i hav try many times bt still dunno hw to do it ! :roll:
this is only applicable to fit only...
1) first remove the headrest.
2) move the seats forward (all the way)
3) press down the backrest (all the way)
tat's all... the backrest should be flushed wif the backseats...
Hondavtec
Re: Diff btw jazz and fit
Post by Hondavtec » Tue Mar 23, 2004 5:13 pm
Crush79 wrote:If i am not wrong, Jazz front seat can be pushed further back for long legged drivers. Fit one is not able to. Correct me if i am wrong.
My Fit can leh.
It is better to try and possibly fail at something than to not try at all
Hondavtec
Post by Hondavtec » Tue Mar 23, 2004 5:14 pm
jazz - 83bhp
fit - smaller
What U trying to do in Ur car :twisted:
adnohzzaj
Post by adnohzzaj » Tue Mar 23, 2004 7:01 pm
jazz - 83bhp
fit - smaller
what else...kekeke
does fit come with buzzer to warn that your light is still on when you off your engine? jazz has this function. quite useful cause see lots of car, parked with light still on.
xRay
Post by xRay » Tue Mar 23, 2004 7:21 pm
adnohzzaj wrote:what else...kekeke
yes it does... guess it's a common function these days...
