Start-up Clutch for Honda City (iDSI)
The second home of www.cityzen.sg
Aslam
Post by Aslam » Mon Oct 29, 2007 2:57 pm
Any bros know where to have e Start-Up Clutch for CVT replaced? What other components relating to e start-up clutch need be replaced due to wear & tear?
Thanks for all kind advice..
Apollo
Re: Start-up Clutch for Honda City (iDSI)
Post by Apollo » Mon Oct 29, 2007 5:17 pm
Aslam wrote:Any bros know where to have e Start-Up Clutch for CVT replaced? What other components relating to e start-up clutch need be replaced due to wear & tear?
not sure wat ur exact problem is..
discussed here before
http://paultan.org/archives/2005/09/04/ ... on-memory/
but if strip gearbox means all the gasket will hv to go and replaced.
might as well replace the ATF filter at same time.
Aslam
Post by Aslam » Mon Oct 29, 2007 6:05 pm
If I get e spares from stockist, would u know any recommended workshop to replace the start clutch, its caskets and all seals? Or is it better to have Kah Motor replace it?
Apollo
Post by Apollo » Wed Oct 31, 2007 11:05 am
since this may end up being a costly affair.
i wud say the judgment call is yours.
goto KM, ask for a quote 1st.
then u can contact outside workshop. I give u one.. elite motor @ sin ming autocare Mr lau 97463035. i hope others contribute a few more workshop or checkout at cityzen.sg
SgtJoe86
Post by SgtJoe86 » Wed Oct 31, 2007 6:48 pm
from the look of it, best guess is for u to go back to KM to change the entire CVT liao, taking it apart juz to replace a damage component doesn't justify the cost.
Aslam
Post by Aslam » Wed Oct 31, 2007 8:02 pm
Apollo wrote:since this may end up being a costly affair.
Thanks bro.. I'll try contacting Mr Lau then... Any bros had similar experience with replacing start-clutch from outside workshop, wld appreciate ur advice...
Aslam
Post by Aslam » Wed Oct 31, 2007 8:03 pm
SgtJoe86 wrote:from the look of it, best guess is for u to go back to KM to change the entire CVT liao, taking it apart juz to replace a damage component doesn't justify the cost.
Already got quote from Kah. The Cost to repair is exobitant man...
Any kind bros had similar experience? Appreciate ur input..
Thks..
Apollo
Post by Apollo » Thu Nov 01, 2007 10:23 pm
Thks..
lidat try asking outside workshop for recon CVT. cud b a lot cheaper.
Vincent72
Post by Vincent72 » Sun Nov 04, 2007 11:03 am
Thks..
wat is cost like to replace the start clutch in KM
SgtJoe86
Post by SgtJoe86 » Sun Nov 04, 2007 10:05 pm
Apollo wrote:lidat try asking outside workshop for recon CVT. cud b a lot cheaper.
from what i know, so far no workshops outside deals with our CVT yet due to the complicated design. gd luck finding one :)
Aslam
Post by Aslam » Mon Nov 05, 2007 4:22 pm
Thks..
In e region of close to 2K including all seals, gasket and installation..
SgtJoe86
Post by SgtJoe86 » Mon Nov 05, 2007 8:22 pm
Aslam wrote:In e region of close to 2K including all seals, gasket and installation..
ouch!!! thats alot :shock:
still have warranty?
Aslam
Post by Aslam » Wed Nov 07, 2007 3:21 pm
Out of warranty... Now accessing whether to fix or to change.. If changing CVTF solve e current issue, would like to drive for another year before changing. If need to fix it at high cost will consider changing ride then...
Toto2216
Post by Toto2216 » Wed Nov 07, 2007 4:50 pm
Maybe can try this workshop
Khang's automatic transmission
blk 21 Sin Ming Ind Est Sec A #01-50
Tel: 6456 5200
but i dunno if they are competent in CVT or not
You'll Never Walk Alone
Aslam
Post by Aslam » Fri Nov 09, 2007 12:57 pm
Thanks to all for ur kind inputs. I had recently change to HMMF fluid and the problem sort of resolved. Now still accessing if there are vibration when moving off from stationary. Hopefully no need to replace start clutch or look for recon CVT gear box....
