FD2R - Owner and those that book
Re: Run in
1,000km can already...LEESM wrote:hi bro,
i just got my ctr on the road, what is the milage for run in, anyone pls advise.
- fruitcakepablohoney
You measured?eiji wrote:10kg for rim weight.fruitcakepablohoney wrote:I was advise by my tyre guru that there's not much choice for 17" rims to clear the calipers & rotors. He advise using the stock 18" size. Also, izzit true the stock rims are damn heavy? Thanks guys in advance!
"LIVE IN ELEVATION OR DIE IN FRUSTRATION"!!!
i believe Ah Bee did, he's a weight freakthexmen wrote:You measured?eiji wrote:10kg for rim weight.fruitcakepablohoney wrote:I was advise by my tyre guru that there's not much choice for 17" rims to clear the calipers & rotors. He advise using the stock 18" size. Also, izzit true the stock rims are damn heavy? Thanks guys in advance!
It is OK, considering it was meant to last a long time. Forged rims can be much lighter, but very expensive. Next time you balance your wheels if you have forged rims, take a close look at the how circular the rims are, especially if used for a few years.fruitcakepablohoney wrote:So is 10kg considered heavy for the stock rims?
Never thought of that, thanks dude!Jimbotan wrote:It is OK, considering it was meant to last a long time. Forged rims can be much lighter, but very expensive. Next time you balance your wheels if you have forged rims, take a close look at the how circular the rims are, especially if used for a few years.fruitcakepablohoney wrote:So is 10kg considered heavy for the stock rims?
meaning not round anymore?Jimbotan wrote:It is OK, considering it was meant to last a long time. Forged rims can be much lighter, but very expensive. Next time you balance your wheels if you have forged rims, take a close look at the how circular the rims are, especially if used for a few years.fruitcakepablohoney wrote:So is 10kg considered heavy for the stock rims?
Juz booked my white CTR today from carz Junction,
Been driving luxury rides for past 2 rides, so this is my first performance ride, some questions to ask.
Wat octance you guys pump? i heard 100 required but i think oni platinum is 100, so most you you pump 98, 95?
Engine oil - wat vicosity to use, i haf been using redline 5w30 for my current ride, i know turbo cars need a diff rating, any diff for the CTR?
Maintence - besides the normal stuff like engine oil, oil filter, air filter, aircon filter, anything additionsl i need to pay attention to?
thanks guys,
Cheers,
Crusnik
thanks guys,
Cheers,
Crusnik
Caltex platinum is only 98 with extra additives just like Shell V-power. Stick with normal 98 is good enough unless $$ is no problem for you.xiidevil wrote:Juz booked my white CTR today from carz Junction,
thanks guys,
Cheers,
Crusnik
Engine oil - 30 or 40 wt oil - 20 too thin, 50 too thick.
Yes. Visible when you spin the wheel on the machine.... this was confirmed by a bro who is in the tyre/rim industry, who had used a few sets of forged rims in the past (he sells forged rims but provided this piece of advice to me).SilveryCivic wrote:meaning not round anymore?Jimbotan wrote:It is OK, considering it was meant to last a long time. Forged rims can be much lighter, but very expensive. Next time you balance your wheels if you have forged rims, take a close look at the how circular the rims are, especially if used for a few years.fruitcakepablohoney wrote:So is 10kg considered heavy for the stock rims?
Cast aluminium are generally more durable for street use. The good ones are slightly heavier than the good forged rims, but cost about the same
I will keep the stock rims, unless of course something happens to them or I strike Toto. Of course if weight is the top priority, forged rims are probably the way to go and many forged rims look very good.
Now the problem I have is finding a replacement for the RE070 when they get worn. These are damn good tyres, but probably not in the wet.
