Page 7 of 25
Posted: Mon Feb 28, 2005 10:41 pm
by EK_Series
2BHIGH wrote:Hi Pete,
Just search thru your DIY of the oil catch tank again and i am interested to DIY one myself similar to your setup too.
Materials to buy :
a) Container - Get those cheap cheap Alu water bottle....
b) Hoses - 5/16" dia - 2m ?
c) Hose clips - 5 or 6 pcs
d) Telfon tape - 1 small roll
e) Metal wool - put in container
f) T or Y joints needed for the PCV hose?
g) Brass hose fittings. 1 L shape + 2 norm. Need any on the PCV outlet,
Drainage outlet need one?
My problem is -
Need to get the hose fittings fixed in the container ready before any installation to be carried out under your guidance.
Fabrication of mounting brkts also a headache.
Anyway to assist?
Wilson: Wanna do this together?
bro, confirm doing ur oil catch tank? may go down and check out how it's done.
Posted: Mon Feb 28, 2005 11:46 pm
by simple
To revive the list again:
Joe - Photographer
Peter - ATF/Caliper
Alex - Heatshield/CAI
Eugene - Entertainment
Darren - Posing
1. Wilson - Heatshield and CAI for intake
2. Jye - TYC Projector Headlamps install
3. Phuturist - ATF cooler
4. 2BHIGH - Chill Out only....can meet u guys for lunch
5. 7Marlboroman - Heatshield
6. EK Type-R (Alex) - Aircon insulation + Chill out
7. Simple - Aircon insulation + chill out (together with Alex)
Posted: Tue Mar 01, 2005 1:51 am
by joon
ok just to highlight a few things about the
oil catch can DIY
if you guys can provide me the materials, i'll be more than happy to help you out with the drilling and fabrication..
BUT it's alot of hassle, and i can't guarantee a good result with the sealing.. i had 2 failed attempts at it.. (ask kuanie, we were supposed to do his.. but after that he just went and bot a used cusco one for $70 and we installed it together.. saved an infinity of trouble.. )
i have to admit this.. you don't save too much by DIYing a can.. material cost will come up to about $50.. more if you screw up.. so maybe it'd be better for you to dig up a used cusco or something.. and i'll help you guys install it
Posted: Tue Mar 01, 2005 2:19 am
by Phuturist
EK_Series wrote:ig108 wrote:Anyone keen on DIY the VTEC indicator light? I can help out on that one....
LED from autobacs, abt $4.90.
Wires, abt $1.00
Easy to connect, difficulty level depends on where you want to locate the LED.
interested to do together. what other things do i need?
how long does the diy job take?
i'm interested too hehe
but will reach there ard 5pm leh
can place anywhere lah
as long as i did it myself, juz doing for fun
Posted: Tue Mar 01, 2005 7:57 am
by ig108
DIY VTEC Indicator Light:
Mat'l
1.) 12 V LED (Can get from Autobacs, near the switches dept. pretty nicely finished ones with chrome ring, abt $5.00/pc green and blue only, Alternatively can get from SimLim Tower, raw ones.)
2.) Resistor (You need this if you want the LED to be dimmer. I do without this.)
3.) Wires. Any 2 thin copper electrical wires.
Tools
a) Black Tape
b) Scissors for wire stripping
c) Drill, for mouting. (I drilled my spare switch plate - the one next to the power mirror switches and mounted the light there)
Time taken to tap the VTEC signal is abt 10mins. To position it in your location and wiring it there will take abt an hour.
Bros pls help me update my name in the list of names of the DIY.... thanks...
Posted: Tue Mar 01, 2005 7:59 am
by ig108
simple wrote:To revive the list again:
Joe - Photographer
Peter - ATF/Caliper
Darren - Posing
8. Ig108 - VTEC Indicator Light + chill out
Posted: Tue Mar 01, 2005 9:44 am
by joon
Joe - Photographer
Peter - ATF/Caliper
Ig108 (
what's your name bro?
) - VTEC Indicator Light
Darren - Posing
8.
9.
Posted: Tue Mar 01, 2005 9:52 am
by HeavyD75
Hey Pete, I see that the DIY fever is really getting higher and higher. Think this DIY session will be one heck of a session.
Posted: Tue Mar 01, 2005 11:17 am
by 2BHIGH
Hmm........in that case
I think I better grab a used Cusco or something.
Get a Y-joint to make it a 3 outlet....
Posted: Tue Mar 01, 2005 1:51 pm
by RichES5
ig108 wrote:DIY VTEC Indicator Light:
Mat'l
Tools
a) Black Tape
Hi Bro, think I've meet you at the Kallang meet-up. Just to to comment on your DIY project.
1) The LED with chrome ring (which I used too) comes in RED, which IMO
looks better (look fierce). Can be purchase at Sim Lim for all color. just
look out for some which is mat in color (not so bright).
2) You don't only use this when you want it dimmer. If you do without
resistor, then you better have extra LED in hand. At 12V your LED will
blow within minutes. I have burn a lot of LED during my trial.
3) Use black (-) and red (+) color so you don't confuse and put wire the
other way round. if you invert them it woundnt work.
One thing I wound advise to get is the black heat shrink tube cost abot $1 per metre at simlim. After solder your resistor to the LED, slip the heat shrink tube in to isolate the + & - . you can heat shrink by heating the tube with the same soldering iron. If the + short the - , there goes a fuse. another $1 gone. I must have blow at least 5 fuse.
if you decide to strip the Vtec Soleniod valve wire (yellow/green), b very careful, it is very tiny wire, you would want to cut them into half. For me, I just plug my wire in the connector without striping them.
Hope my comment is of some help, so good luck & happy DIY.
Posted: Tue Mar 01, 2005 3:58 pm
by joon
RichES5 wrote:Hope my comment is of some help, so good luck & happy DIY.
yo bro! thanks for the info.. great job you did on darren's car
Posted: Tue Mar 01, 2005 4:25 pm
by ig108
Hi bro, Thanks for the tips. Yes, do agree that your method is more secure and professional! For the LED, as it was from Autobacs, the ratings are meant for cars, so far, still serves me alright. You're right that the sim lim ones needs resistor. So, bros here, pls note.
& yes, I nearly severed the VTEC wire while stripping it... so your method of plugging in is better.
BTW, you shld come for the DIY meetup as well. I think you can volunteer your knowledge on DIY the grills at the bumper areas... its cheaper....this is one mod that I may do on that day....
Posted: Wed Mar 02, 2005 10:45 am
by RichES5
When is the "Mod Day" happening, have to check my schedule or rather my OC schedule lah.
Posted: Wed Mar 02, 2005 10:48 am
by RichES5
joon wrote:RichES5 wrote:Hope my comment is of some help, so good luck & happy DIY.
Thanks bro, What I did have no comparison with your art man. love to meet you one day and learn from you. As for Darren car, that is a "troublesome" car. opss, hope he dont read this.(dont worry darren still under friendship warranty) Cheers
Posted: Wed Mar 02, 2005 11:17 am
by thepukster
Haha! Caught you!!!
But on a serious note, Richard is pretty dar good with his LED conversion man....
