Post
by carbon82 » Mon Feb 26, 2007 1:16 pm
<U>Technical Specifications</U>
Ext Dimensions: 4,285mm (L) x 1,755mm (W) x 1,670mm (H)
Int Dimensions: 2,500mm (L) x 1,430mm (W) x 1,260mm (H)
Wheelbase: 2,700mm
Ground Clearance: 185mm
Track (Front / Rear): 1,515mm / 1,505mm
Min. Turning Radius: 5.3m
Tyre Size: 215/65R16 [1.8], 215/60R17 [2.0]
Weight: 1,410Kg (1.8L FF) - 1,520Kg (2.0Xi 4WD)
Engine: 1.8L SOHC i-VTEC (R18A) & 2.0L SOHC i-VTEC (R20A)
Engine Capacity: 1,799cc / 1,997cc
Bore & Stroke: 81.0mm × 87.3mm (R18A) / 81.0mm × 96.9mm (R20A)
Compression Ratio: 10.5:1
Max. Horsepower: 140ps/6,300rpm [1.8] & 150ps/6,200rpm [2.0]
Max. Torque: 174Nm/4,300rpm [1.8] & 190Nm/4,200rpm [2.0]
Transmission: 5 Speed Auto
Fuel Consumption (Japan 10-15 mode): 13.8Km/L [1.8 FF], 13.4Km/L [1.8 4WD], 13.8Km/L [2.0 FF], 12.4Km/L - 13.2Km/L [2.0 4WD]
