Fuel consumption question
+1Gresini wrote:Personal opinion: dun really advise to add other thing to solve yr prob. Look for the source and treat it direct maybe better?
Try to maintain it properly, like oil change regularly, Clean Your throttle body, check valve clearance to stock specs.(can help performance & mileage ofcourse!)
Check your tires pressure.
& last but not the least.. Step lightly on the gas untill it accelerates.
VTEC power!
Suspect you have compression leak somewhere hence the lousy fuel comsumption. Could be your engine head if the water is disappearing all the time. Bring to a workshop and check would be the best. If dunno any good ones just ask the guys here.shellshox wrote:I do have to top up the radiator water every other month but speed wise, there's still power and speed in the mid range. Will any workshop have the equipment to rechip or I have to go specific ones? Have been going to CL for awhile...
Nice car BTW....
