Advice needed for "shivering" of car
abcde83
Post by abcde83 » Mon Jan 11, 2010 8:56 pm
seems like my ES has alot of vibration...
when stationary, aircon shivering caused the vibration..
when travelled above 100km/hr the steering wheel vibrate (did wheel balancing liao, i guess the ppl nv do a proper job for me...)
feels like driving a van.... :cry:
abcde83
Post by abcde83 » Thu Mar 11, 2010 12:33 am
airborne wrote:
abcde83 wrote:
airborne wrote:bro when i first bought my car i had a similar problem.. mech says its a engine mounting problem.. one of the mounts was faulty and he replaced it at a pretty low cost.
problem solved.
but after my recent accident the problem resurfaced .. the impact probably loosened the mounting? not sure yet.. but ill get it checked and ill get back to you
(throttle body cleaned recently, no improvement to "shivering")
how much it cost to change the engine mounting?
my car does shiver too when idling....
i tot something wrong with the compressor or the engine mounting...
it's a 2005 ES5.
i checked my receipt dated one year ago when i replaced my engine mounting.. (not sure how many the mech replaced, but it solved the shivering then)
cost is $250 including labour. jurong area
u got the address for the ws where u did the engine mounting?
thanks.
silver8_0
Post by silver8_0 » Mon Mar 29, 2010 11:12 pm
abcde83 wrote:
airborne wrote:
abcde83 wrote: how much it cost to change the engine mounting?
it's a 2005 ES5.
thanks.
Hi bros, so u able to solve ur "shivering" problem?
Jus send my car to the 80k servicing and according to the advisor, he mention tat this is usually the case for fd4 and it happens bcos when the aircon compressor kicks in, it draw power, causing the rpm to drop, and when it drop, the car will "shivers".
According to him, the car will still shiver and guess the engine mounting will only help to prevent us from feeling the shivering.
snuka00
Post by snuka00 » Sat Feb 19, 2011 2:45 pm
my car also have this shivering problem.... i'm driving a CL7A.
cchongs
Post by cchongs » Tue Mar 01, 2011 10:26 pm
snuka00 wrote:my car also have this shivering problem.... i'm driving a CL7A.
Seems to be a common problem for Honda Civic..... i have complained a few times to KM but throttle cleaning and others has been done.... but nothing has changed ever since.
Has any brothers and sisters here had experience to solve it once and for all?
Engine mounting faults is possible but if it doesn't solve the problem, then its again a waste of money!!!
Flying Eagle
AN
Post by AN » Thu Mar 17, 2011 5:47 pm
my model is CM4.
Just went to have the car mechanic checked, he told me it is the enginer mounting issue on the "shivering". But I am skeptical on it. So i tried to have the throttle body clean and now monitoring.
btw, what is the damage to change the engine mounting? Anyone?
fiqueudrue
Post by fiqueudrue » Tue Aug 16, 2011 8:48 pm
vibration could be eng mtg.
taymichael
Post by taymichael » Sat Jan 07, 2012 8:12 am
Sent to KM for throttle body cleaning twice, tune the idling rpm up and have the engine mounts replaced - yet the problem surfaced weeks after. Not sure if this problem is inherent in my '08 1.6 civic or KM did not do a proper throttle body cleaning. Any further advise anyone?
best20
Post by best20 » Thu Nov 01, 2012 10:20 pm
Hi Guys.
I just bought a 2nd hand 2007 Civic.
What is a recommended engine mount, saw Hasport Mount, is that a good engine mount?
Need some advise before I do a change.
TIA
speedsterdarren
Post by speedsterdarren » Wed Dec 12, 2012 3:57 pm
IMO 3 possibilities...
1)Engine Mounting
2)Idling Valve Faulty
3)Tappet Clearance needs to be checked.
Hope this helps... :wink:
Slong
Post by Slong » Fri Dec 14, 2012 7:12 pm
After cleaning your throttle body, mostly likely its either the engine mounting or the plug coil that need to be check. Before you start your vehicle, it's starts the virbrate?
JasonRain
Post by JasonRain » Wed Jan 30, 2013 4:31 pm
If car is still under warranty, go back to KM.
_________________
WoW Gold Kaufen|Diablo 3 Gold|Runescape Gold|GW2 Gold
