Page 9 of 25
Re: CAI tubing
Posted: Thu Mar 03, 2005 12:37 pm
by joon
zippyalex wrote:If anyone wants to do that, pls get some thing to block out the inlet to IM. If you have those momo knobs, you should have some spare rubber bung, i used that with a 1/4" hose clip. No sweat.
haha you know what else works? the rubber feet used to cap over the legs of steel chairs to prevent the from screeching and scratching the floor.. get the 12mm round ones hhaha
Re: CAI tubing
Posted: Thu Mar 03, 2005 4:17 pm
by 2BHIGH
Called up Able Hydraulics and they have everything I need.
Will be heading down on sat to buy them.
Thks Pete for the heads up.
Am gonna get
a) 4 metres of 1/2" dia hose
b) 2 x brass fitting ( T-joint )
c) Some extra hose clips
d) Anything else I have left out ?
As I am currently using a mini breather filter, I used black tape to mask off the opening of the hose to the IM.
Regards,
Re: CAI tubing
Posted: Thu Mar 03, 2005 4:26 pm
by joon
2BHIGH wrote:a) 4 metres of 1/2" dia hose
Regards,
see if you can get a Y-joint, flow is better.. use a plug bolt instead of black tape.. that deteriorates over time and can get sucked into the intake manifold
Posted: Thu Mar 03, 2005 5:07 pm
by HeavyD75
Pete... regarding the heatshield for my openpod. Was going through some of the websites. Do you think the heatshield can be done using a plastic dustbin, and cut it to shape?
Posted: Thu Mar 03, 2005 5:30 pm
by joon
HeavyD75 wrote:Pete... regarding the heatshield for my openpod. Was going through some of the websites. Do you think the heatshield can be done using a plastic dustbin, and cut it to shape?
hahaa isn't that what i did the last time??!
yeah.. go to the toyogo warehouse at toa payoh ind estate haha.. lots of shapes and sizes for you to choose from
that's what i did last time.. it's fun but it's alot of work..
by 2BHIGH
Wilson
I have some foam which is Grey in colour, single-side with adhesive.
605mm x 385mm ( 5 pcs )
Around 5mm thick.
Duno if its useful for your DIY heat shield. If u need, i can bring it down on the 19th March 05.
Regards,
Posted: Thu Mar 03, 2005 5:35 pm
by HeavyD75
2BHIGH wrote:Wilson
Around 5mm thick.
Regards,
Hey bro... why don't i meet up with u tonite to see it?
Posted: Thu Mar 03, 2005 5:39 pm
by 2BHIGH
Tonight going movie with Ministeress of State leh.....
Nevermind lah, i just bring on the 19th Mar and see needs it.
Use 2 pcs and stick them together with a Alu sheet in between and u got a wall thickness of 10mm.
Posted: Thu Mar 03, 2005 5:41 pm
by HeavyD75
2BHIGH wrote:Tonight going movie with Ministeress of State leh.....
Bro, I've the same thinking as well... HA! Great! Bring it down! Bring it down! I am sure it'll work! Or this sat?
Posted: Thu Mar 03, 2005 5:46 pm
by 2BHIGH
This sat also tied up...
Going to HDB in the morning and then rushing to Able Hydraulics to buy stuffs for the DIY oil catch tank.
C u on the 19th.
Posted: Thu Mar 03, 2005 5:55 pm
by HeavyD75
2BHIGH wrote:This sat also tied up...
C u on the 19th.
Ok ok... c u then.
Posted: Wed Mar 09, 2005 9:50 am
by joon
ok bros.. for those who're interested to join.. please update the list again as to what you guys will be doing.. i know wilson's got his heatshield fixed, so anyone else?
i might strip out my interior and do some cleaning haha
Posted: Wed Mar 09, 2005 9:52 am
by HeavyD75
joon wrote:ok bros.. for those who're interested to join.. please update the list again as to what you guys will be doing.. i know wilson's got his heatshield fixed, so anyone else?
Pete, I still need your help in fitting the rear strut and in addition a arospeed oil catchtank.
Posted: Wed Mar 09, 2005 9:57 am
by DIRT22
Why not you clean my engine bay for me lah??
Will be washing and polishing car I guess.....nothing to DIY for my car lah, unless you got some 3M mounting tape I can steal (I'm all out!) then I'd wanna reposition the control units and VFCII.......
Posted: Wed Mar 09, 2005 10:12 am
by EK_Series
DIRT22 wrote:joon wrote:ok bros.. for those who're interested to join.. please update the list again as to what you guys will be doing.. i know wilson's got his heatshield fixed, so anyone else?
may join u guys on the 19th. if you want, i still have leftover 3m mounting tape. you can have it.
