i recently bought a used honda airwave 2007. it has a problem with the rpm. sometimes when accelerating rpm holds on 2000 for few seconds and suddenly release and rpm reach to 3000 car jerks and comes back to normal and again. sometimes gears will not shift till rpm reaches to 3000-3500 and even worse sometimes 'D' start blinking and losses power. and at the speed approximately 50-70 rpm is not stable. it goes up and down continuously. but at the highway all seems ok.
to resolve this i have done following things,
replaced gearbox
cleaned fuel pump
replaced spark plugs
cleaned EGR valve and throttle body including TPS
checked cam and crank sensors
checked oxygen sensor
unfortunately none of above helped.
rpm not stable
Re: rpm not stable
have you checked the IAC or some called Air control Valve?
Sent from my iPhone using Tapatalk
Re: rpm not stable
yes i have checked the throttle body replacing new one.
- 2000rpm
Re: rpm not stable
Since u had replace gb, guess must be ur ecu problem....u may want to try change to another ecu or get aftermarket n tune...
Sent from my SM-G360G using Tapatalk
Re: rpm not stable
so far that is my only doubt. will have to check that. thanks
Re: rpm not stable
U can try changing the block.
