ideal rim size for odyssey RB3
Strictly tyres and rims talk
Sean
Postby Sean » Tue Aug 24, 2010 1:48 am
looking to upgrade stock rim.
any ideal which is the best size.
oso, anyone knows the PCD offset of this mpv?
Rgds,
Sean
Nov
Postby Nov » Thu Aug 26, 2010 12:32 pm
I think the PCD is 5-114.3
At least thats what I see in the websites below...If not, is it possible to check from the manual?
http://goods.autoc-one.jp/wheel/honda/odyssey/
http://www.mzspeed.co.jp/wheel/jjChromo ... gData.html
- Nov -
09 Miku RB3 ODC
Slow and not so steady...
TCN
Postby TCN » Thu Aug 26, 2010 2:06 pm
Yes, the PCD is 5-114.3
The offset for both the factory fitted EX model rims (215/60 R16) and EXV model (215/55 R17) are +55. I am driving the EX model with 16" rims and recently upgraded to the factory fitted 17" rims (take-off rims). I took a look at both the rims during the change in the tyre shop and noticed both the offset are +55 (engraved on the inside of the rims). And both rims are made by Enkei.
The answer to your question on the ideal size is dependant on what you look for - comfort, handling or look. 16" tyres gives you more comfort (on stock A349 tyres). I find my new 17" tyres (bridgestone GR90) have better handling (eg cornering) but the ride is slightly harder and noiser. In terms of look, I find 17" look more balanced with our long car, plus the 16" rims is more difficult to clean.
If you ask me whether I'll do it again if given a choice, the answer is yes.
By the way, I realize after doing some research that all regular odysseys sold in Japan are on 16" tyres, except the Absolute version. I suppose the Japs may value comfort more than handling.
Hope this helps.
Sean
rims
Postby Sean » Thu Aug 26, 2010 6:41 pm
TCN wrote:Yes, the PCD is 5-114.3
Hope this helps.
Hi there,
i m considering between 17 & 18"
becos up 1 size dun seems to be very value for money( i am changing to other rim makes).
but up to 18" dunno will be very hard and noisy on ride or not....
i oso looking for the KNN drop-in filter but to no avail...
have u change tat too? i not in mod so only keen to change the batt,filter and rims.... as i find our engine is very powerful liao...
Rgds,
Sean
wilson76
Re: rims
Postby wilson76 » Sun Aug 29, 2010 11:13 pm
18" is better in terms of looks.noise is dependent on tyre profile and brands. I am letting go my brand new 8kg forged rim which is one of the lightest 18" in the market, save FC and better acceleration. Oh and reason for selling is because I am using back my old repaired rim which was down for a week.
Hope this helps.
Hi there,
:D :wink: :wink:
wilson76
Postby wilson76 » Sun Sep 05, 2010 12:33 am
http://www.prodrive-japan.com/products/ ... llery.html
There is an Odessey inside the prodrive's gallery. Can view as reference for info. :wink:
Sean
prodrive
Postby Sean » Mon Sep 06, 2010 1:47 am
wilson76 wrote:http://www.prodrive-japan.com/products/gc_05k/gallery.html
but it don't look good on Odyssey. spoke too thin. odyssey got alot of metal.... further more the one in the pic seems 19/20 inch..
Rgds,
Sean
ODYXPRESS
Postby ODYXPRESS » Tue Oct 18, 2011 9:24 pm
Revive this thread...
Factory Rims Offset 55
Can fit 45 but will protrude so if lower will have problems?
Or Do 50 ( to be safe)
So who has the nice Flush look and can advise...
Thxs for the Advice...
dldm
Postby dldm » Wed Oct 19, 2011 4:09 pm
ODYXPRESS wrote:Revive this thread...
if get 45offset, dun get too big rims, get 16 or 17 inch ok liao
these r the few types
http://www.efxsoft.com/sgtyres/tr1c.asp ... &rimdia=00
City1972
Postby City1972 » Fri Oct 21, 2011 2:59 pm
So many ads in the forum...
Lex799
Postby Lex799 » Thu Aug 28, 2014 2:43 pm
Hi There..
Can someone tell me if this set of rims can fit a RB3 Odyssey- 19 inches PCD 5 X 114.3 rims front 8.5 offset 35 & rear 9.5 offset 40.
I am considering changing to this set from the stock 17inch oem setup.
Many thanks in advance.
Rgds,
Lex799
parameswaryshana
Re: ideal rim size for odyssey RB3
Postby parameswaryshana » Tue Nov 24, 2015 6:17 pm
I have rb3 original rim 18inch
Sent from my SM-N910G using Tapatalk
Return to “Tyres And Rims”
Who is online
