Hi all pros, could you advise on my issue listed below and also any remedy. been looking around the forum but none seems to show my issue.
1.random jerking when on slow or up slope on indoor carpark which seems unusual.
2.random jerking like on hump feeling on expressway moving fast. 70kph-100kph
3.always feel that vehical sliding to left ( already went for servicing but the tech says no issue with suspension and tires done rotating.) feels like the wheels are very loose. (16 inch tire when bought over falken)
any remedy for the above solution before i conclude is cvt issue as i do not have random rpm plunges, just feel that quite rough on the engine. drove for around 7 months after i got this vehicle and the above problem surface.
Honda Fit 2008 Juddering/jerking
Re: Honda Fit 2008 Juddering/jerking
hi,
have you sent to any workshop to check on it, you can find a list of workshop in the general discussion section. it is better to have it checked and advised soon before it leads to other drivability or maintenance issues.
for the veering left, some say it's due to the design of the roads. it is not flat but there is a slight slopping towards the left to facilitate rain drainage. or it could be wheel alignment (different from tire balancing) since i don't know how the situation develops under what conditions.
hope it helps.
hope it helps.
