DIY Day Part 6: Postponed to May
DIY Day (Afternoon)
March 12 (Sat)
3
19%
March 19 (Sat)
3
19%
March 26 (Sat)
3
19%
Any day is fine with me
7
44%
Total votes: 16
joon
Re: CAI tubing
Post by joon » Thu Mar 03, 2005 12:37 pm
zippyalex wrote:If anyone wants to do that, pls get some thing to block out the inlet to IM. If you have those momo knobs, you should have some spare rubber bung, i used that with a 1/4" hose clip. No sweat.
haha you know what else works? the rubber feet used to cap over the legs of steel chairs to prevent the from screeching and scratching the floor.. get the 12mm round ones hhaha :wink:
2BHIGH
Re: CAI tubing
Post by 2BHIGH » Thu Mar 03, 2005 4:17 pm
Called up Able Hydraulics and they have everything I need.
Will be heading down on sat to buy them.
Thks Pete for the heads up.
Am gonna get
a) 4 metres of 1/2" dia hose
b) 2 x brass fitting ( T-joint )
c) Some extra hose clips
d) Anything else I have left out ?
As I am currently using a mini breather filter, I used black tape to mask off the opening of the hose to the IM.
Regards,
joon
Re: CAI tubing
Post by joon » Thu Mar 03, 2005 4:26 pm
2BHIGH wrote:a) 4 metres of 1/2" dia hose
Regards,
see if you can get a Y-joint, flow is better.. use a plug bolt instead of black tape.. that deteriorates over time and can get sucked into the intake manifold :wink:
HeavyD75
Post by HeavyD75 » Thu Mar 03, 2005 5:07 pm
Pete... regarding the heatshield for my openpod. Was going through some of the websites. Do you think the heatshield can be done using a plastic dustbin, and cut it to shape?
VTEC roars to Eternity!... Live the POWER OF DREAMS.
Gotto Love my D! Simply amazing!
joon
Post by joon » Thu Mar 03, 2005 5:30 pm
HeavyD75 wrote:Pete... regarding the heatshield for my openpod. Was going through some of the websites. Do you think the heatshield can be done using a plastic dustbin, and cut it to shape?
hahaa isn't that what i did the last time??! :roll:
yeah.. go to the toyogo warehouse at toa payoh ind estate haha.. lots of shapes and sizes for you to choose from :D that's what i did last time.. it's fun but it's alot of work..
2BHIGH
Post by 2BHIGH » Thu Mar 03, 2005 5:30 pm
Wilson
I have some foam which is Grey in colour, single-side with adhesive.
605mm x 385mm ( 5 pcs )
Around 5mm thick.
Duno if its useful for your DIY heat shield. If u need, i can bring it down on the 19th March 05.
Regards,
HeavyD75
Post by HeavyD75 » Thu Mar 03, 2005 5:35 pm
2BHIGH wrote:Wilson
Around 5mm thick.
Regards,
Hey bro... why don't i meet up with u tonite to see it? :D
2BHIGH
Post by 2BHIGH » Thu Mar 03, 2005 5:39 pm
Tonight going movie with Ministeress of State leh.....
Nevermind lah, i just bring on the 19th Mar and see needs it.
Use 2 pcs and stick them together with a Alu sheet in between and u got a wall thickness of 10mm.
HeavyD75
Post by HeavyD75 » Thu Mar 03, 2005 5:41 pm
2BHIGH wrote:Tonight going movie with Ministeress of State leh.....
Bro, I've the same thinking as well... HA! Great! Bring it down! Bring it down! I am sure it'll work! Or this sat? :roll:
2BHIGH
Post by 2BHIGH » Thu Mar 03, 2005 5:46 pm
This sat also tied up...
Going to HDB in the morning and then rushing to Able Hydraulics to buy stuffs for the DIY oil catch tank.
C u on the 19th.
HeavyD75
Post by HeavyD75 » Thu Mar 03, 2005 5:55 pm
2BHIGH wrote:This sat also tied up...
C u on the 19th.
Ok ok... c u then.
joon
Post by joon » Wed Mar 09, 2005 9:50 am
ok bros.. for those who're interested to join.. please update the list again as to what you guys will be doing.. i know wilson's got his heatshield fixed, so anyone else? :wink:
i might strip out my interior and do some cleaning haha
HeavyD75
Post by HeavyD75 » Wed Mar 09, 2005 9:52 am
joon wrote:ok bros.. for those who're interested to join.. please update the list again as to what you guys will be doing.. i know wilson's got his heatshield fixed, so anyone else? :wink:
Pete, I still need your help in fitting the rear strut and in addition a arospeed oil catchtank. :?
DIRT22
Senior Moderator
Senior Moderator
Answers: 1
Post by DIRT22 » Wed Mar 09, 2005 9:57 am
Why not you clean my engine bay for me lah?? :lol:
Will be washing and polishing car I guess.....nothing to DIY for my car lah, unless you got some 3M mounting tape I can steal (I'm all out!) then I'd wanna reposition the control units and VFCII.......
EK_Series
Post by EK_Series » Wed Mar 09, 2005 10:12 am
may join u guys on the 19th. if you want, i still have leftover 3m mounting tape. you can have it.
