Where to change Air con Fan cheap and good?
minmax
Post by minmax » Sat May 04, 2013 7:54 pm
Hi bros,
anyone know where to change aircon fan cheap and good?
for civic 2006
thanks
abbey
Post by abbey » Fri May 17, 2013 2:16 pm
There are lots of cheaper brands available but for durability choose the original part like fan because its increase the life. Cheaper products reduce the output and damage the other parts.
cl7teckie
Post by cl7teckie » Sat May 18, 2013 8:57 pm
abbey wrote:There are lots of cheaper brands available but for durability choose the original part like fan because its increase the life. Cheaper products reduce the output and damage the other parts.
Well, cheaper parts may or may not result in longer life. While I am not towards OEM or other brands, for technical reasons, but I disgreed with your reason.
1. The products normally does NOT reduce output.
2. This fan motor does NOT damge other parts.
The real problem is, fan motor is so "generic" that it is almost one size fit all. As such, a lot of part stockist, buy one for all. It is up to the installers to identify the difference and delta and make modification. Problems like wires too long or short is common. Some installer will just cable tie all these extra wires, rather than installing it correct.
One last aspect is the present of EMI filter in a lot of model. OEM motor will never comes with this filter. Do you think any installer will bother to cut and paste this filter. Some even tell you it is a resistor or a ballast....muahahaha
Pls dont ask me for wkshop, as I know none...I only know it is safer and faster to fix cars on my own.
