New Honda city, Not smooth when gear changes
eug3n3_ang
- 2000rpm
Hi guys,
Anyone encounter same problem on the gear change from 1 to 2 and 2 to 3. Feels like there is a force pulling back when switching gear.
Somehow the same feeling when i drive manual and throw clutch.
Is it becoz i nv step enough accelerator?
May i know how to solve it?
Thanks in advance.
Thanks in advance.
Re: New Honda city, Not smooth when gear changes
City auto?eug3n3_ang wrote:Hi guys,
Thanks in advance.
[quote="eug3n3_ang"]Hi guys,
Thanks in advance.[/quote]
Bro, did you get it fixed? I'm having the same problem when moving off from cold engine. KM told me it is normal.
- fiqueudrue
- 8000rpm Red Line
alvinchoo86
- 3000rpm
funkychicken
- 5000rpm
Change engine oil and transmission oil. Use oem honda atf or hmmf fluid for ur car. Basic servicing is critical. Clean air filter if u using drop in or oem one change. All this basic servicing need to do religiously. For a start wif ur air filter. Can be cause by lots or reasonsbut always start wif basic servicing when troubleshooting.
