Anyone knows about this Euro R?
Home Of The Accordians
jaymen
Post by jaymen » Sat Oct 20, 2012 6:27 pm
Hi bro's,
I am considering to get this Euro R.
Test drove it couple of weeks back and its the best among the many I have viewed/test driven. Does anyone know any history or something I should be aware off? Any thoughts are welcomed.
http://www.sgcarmart.com/used_cars/info ... 67&DL=1015
viper76
Post by viper76 » Sun Oct 21, 2012 7:36 pm
hmm saw tis R before but can't remember which owner ixxit....btw 19 inch rims is a over kill...if u get tis car go downgrade to 18 or best 17 ....if u stick to 19 gd luck to ur FC...
jaymen
Post by jaymen » Mon Oct 22, 2012 12:30 am
viper76 wrote:hmm saw tis R before but can't remember which owner ixxit....btw 19 inch rims is a over kill...if u get tis car go downgrade to 18 or best 17 ....if u stick to 19 gd luck to ur FC...
Hi Kelvin, thank you for your response on my previous post and this one. I am with you on the rims and my plan is to look for the stock standard 17' rims if I do proceed to get this car. Do you think I should be worried about any other components considering the car has been running on the 19's currently?
walterpan
Post by walterpan » Mon Oct 22, 2012 9:21 am
best to get from direct owner...
Rcar
Post by Rcar » Mon Oct 22, 2012 3:35 pm
if the rim is light, it should be of much difference between 17 vs 19.
viper76
Post by viper76 » Sun Oct 28, 2012 9:38 am
bro if the 19 inch rim very light tat means tat rim must be super expensive man...but frm the pic i doubt the 19 inch is a ex rim...
jaymen
Post by jaymen » Sun Oct 28, 2012 11:58 am
Hey bro's, after much searching and many test drives, I have decided to purchase the unit below:
http://www.sgcarmart.com/used_cars/info ... 59&DL=1128
This runs on 17" rims but uses the D2 Coilover which is pretty stiff...I plan to change to standard shocks at some point
viper76
Post by viper76 » Sun Oct 28, 2012 9:33 pm
jaymen wrote:Hey bro's, after much searching and many test drives, I have decided to purchase the unit below:
try to adjust the damping....might help to sofer the hardness..can click make it soft or hard..dun bother going back to stock shocks unless u really really want comfort for family...coilovers can be accepted by family members as well so jus my 2 cents dun waste money bro
jaymen
Post by jaymen » Mon Oct 29, 2012 12:45 am
Thanks for the tip bro...I ll go with your recommendation and see what the outcome is first :)..Thanks again bro
