LC
- Idling
Post
by LC » Thu Jun 21, 2012 2:10 pm
Help... I have a problem with my Honda Edix Gear lever. Every time I shift it to "P", the gear will be lock in the position. I have to insert a key into the small hole beside the gear to released the lock. I've check with my workshop, they told me there are no spare part in singapore to fix my problem. I was told that the Gear Lever Locking Switch is spoilt. Does anyone out there have advise or solution for me...
jellyfish
- 7000rpm VTEC ON
Post
by jellyfish » Thu Jun 21, 2012 10:10 pm
LC wrote:Help... I have a problem with my Honda Edix Gear lever. Every time I shift it to "P", the gear will be lock in the position. I have to insert a key into the small hole beside the gear to released the lock. I've check with my workshop, they told me there are no spare part in singapore to fix my problem. I was told that the Gear Lever Locking Switch is spoilt. Does anyone out there have advise or solution for me...
pls give your brake pedal sensor a check, high chance its spoiled , and check if your rear brake light is not working, cos if its a brake pedal sensor switch spoiled then got cure.
mango
LC
- Idling
Post
by LC » Fri Jun 22, 2012 5:37 pm
Hi thanks very much... I've test my brake.. All brake light not working... So meaning, I can go to the workshop to fix my brake pedal sensor switch.. Any idea how much it's cost?
LC
- Idling
Post
by LC » Fri Jun 22, 2012 6:15 pm
Btw, is there any workshop dealing with honda parallel import cars? Let me know if you have any good workshop that can fix Honda cars.. Thank you very very much!
WSLBCL7
- 4000rpm
Post
by WSLBCL7 » Sat Jun 23, 2012 5:28 am
LC wrote:Btw, is there any workshop dealing with honda parallel import cars? Let me know if you have any good workshop that can fix Honda cars.. Thank you very very much!
Still a honda no matter PI or not, there's lots of WS u can do a search for your model...
jellyfish
- 7000rpm VTEC ON
Post
by jellyfish » Sat Jun 23, 2012 9:20 am
LC wrote:Hi thanks very much... I've test my brake.. All brake light not working... So meaning, I can go to the workshop to fix my brake pedal sensor switch.. Any idea how much it's cost?
cheap lah, it won`t cost you an arm or leg, if it aint working check fuse first then if fuse is ok then check sensor got connectivity or not. but i`ll put my bet on the sensor
go to reputable workshop, i just hate it when they anyhow whack and humtam problem and go for the most expensive solution
mango
LC
- Idling
Post
by LC » Sun Jun 24, 2012 9:49 am
Thanks! I will do it tomorrow.. I think the car really short circuit already...
The hone is not working too... Not sound at all... Not sure if there are other things not working???
jellyfish
- 7000rpm VTEC ON
Post
by jellyfish » Mon Jun 25, 2012 10:58 am
LC wrote:Thanks! I will do it tomorrow.. I think the car really short circuit already...
fix the sensor the horn will be back one
mango
LC
- Idling
Post
by LC » Mon Jun 25, 2012 5:25 pm
Thank you very much!!!
Fuse change... The car is now back to normal...
Didn't know this small fuse cause so much problem... Lol... Thanks again...
jellyfish
- 7000rpm VTEC ON
Post
by jellyfish » Tue Jun 26, 2012 4:24 pm
good to know you don need to shell out so much and not being chopped by greedy car shops
mango
screwloose
- 2000rpm
Post
by screwloose » Thu Jun 28, 2012 3:24 pm
Edix got the shift lock fuse blown issue....i suggest u keep couple of fuse for rainy days
