any workshop provide machine bore service for throttlebody?
realgetz
Post by realgetz » Tue Dec 13, 2011 10:19 am
hi, anyone knows which workshop does boring service for stock throttle body. and able to do e throttle. only need to do taper bore. THANKS!!!!
AlanZ
Re: any workshop provide machine bore service for throttlebo
Post by AlanZ » Sat Jan 28, 2012 12:50 pm
realgetz wrote:hi, anyone knows which workshop does boring service for stock throttle body. and able to do e throttle. only need to do taper bore. THANKS!!!!
Quite a few around. You toking about machine or hand bore?
yeobt
Post by yeobt » Mon Mar 05, 2012 9:37 pm
Machine for me.
Any lobang?
After Spending So Much Time And Money To Own A Car,
You Must Learn To Enjoy The Fun Of Driving It,
Not Stressing Yourself On Your Journey Home.
ah_rek
Post by ah_rek » Wed Mar 07, 2012 2:08 pm
i duno why people are looking into bore a throttlebody.
do you really know what you need? or just bore for the sake or BORING?
i've seen car being more slugish, throttlebody cracked, butterfly jam. But i don't see a need to bore throttlebody... esp when you only bore by 1mm.
just my 2cents,
i've been driving ek3 sohc and i know what it needs
slow is gold.
kozmix
Post by kozmix » Wed Mar 07, 2012 4:16 pm
bore already but butterfly still same size bore for wat ? dont get con by those sux workshop
change bigger TB
You know you're so JDM when your black underwear have red stitchings.
yeobt
Post by yeobt » Wed Mar 07, 2012 4:43 pm
Make sense.
Thanks for the valuable points.
EK Type-R
Post by EK Type-R » Thu Mar 08, 2012 12:26 am
kozmix wrote:bore already but butterfly still same size bore for wat ? dont get con by those sux workshop
change bigger TB
EK9/EK4 stock 60mm TB.. best upgrade for EK3 Vi-RS.. :wink:
