Black smoke from exhaust(advise needed)
stryker
Post by stryker » Sat Jan 08, 2011 10:43 pm
Hi, my friend encounter black smoke discharge from exhaust when engine is hot, need some advise what to check, tks
STRYKER IS BORN
saint jo
Post by saint jo » Mon Jan 10, 2011 7:52 am
engine oil gg into combustion liao...
small case is casket spoil...big case is piston ring..piston...even engine block...
Turbo...
sTocK iS beST....
世界上ä¸
UltraBear
Re: Black smoke from exhaust(advise needed)
Post by UltraBear » Mon Jan 10, 2011 12:03 pm
stryker wrote:Hi, my friend encounter black smoke discharge from exhaust when engine is hot, need some advise what to check, tks
==> if its black smoke, still not so bad... could be running too rich or spark plug up the lorry liao... since it only happen when engine is hot, check and replace spark plug first...
