Deleted..
- chayfoocheong
- 4000rpm
Since I plan to upgrade my b16 intake manifold, what should i go for?
- Bore the stock b16 one?
- Type R intake manifold from ek9 or dc2?
- Skunk2?
- Any other brand?
Hard skunk 2 is good but design same as type R one? So if get type R one is a good upgrade for B16 stock intake manifold?
Pls advise.... Thank u in advance
- Skunk2?
- Any other brand?
- chayfoocheong
- 4000rpm
Sting3Rhea
- 7000rpm VTEC ON
paxidorm wrote:ok..actually interested to know whether upgrade of intake manifold to type R or skunk2 help in improving the performance in term of different RPM range. e.g. difference in high/mid/low rpm? Because from what i know B16 and type R are both 62mm
http://www.skunk2.com/engine-2.php?code=INPROB
Intake
Heya there guys..
Just to clarify things here both have the equal diameter in their plenum only diffrence is the throttle body that their using.. One is bigger by 2mm.. And the fact that dc2 has its iats (intake air temp sensor) mounted on the manifold itself while ek9 iats is located at the CAI before the throttle body..
HTH
HTH
